Diagnosis Murder.. Shuddering Under Braking
#21
Posted 22 April 2014 - 07:46 PM
#22
Posted 22 April 2014 - 08:03 PM
#23
Posted 22 April 2014 - 09:05 PM
#24
Posted 23 April 2014 - 10:26 AM
Maybe as metal heats up it doesn't always uniformly expand across the surface? The hotter the discs get the greater the disparity between the big bits and the little. This could cause the shake and explain why it gets worse the harder you work the brakes?
Just a thought though, could be something else
I used to get this though, changed my discs recently and didn't notice it on Sunday so may have got lucky
#25
Posted 23 April 2014 - 11:26 AM
#26
Posted 23 April 2014 - 11:44 AM
#27
Posted 23 April 2014 - 12:34 PM
Ping Duncanf, I remember years ago going out with him and identical problem, not sure what he did to sort it.
#28
Posted 23 April 2014 - 12:38 PM
will do
#29
Posted 23 April 2014 - 01:05 PM
Brake fluid.
That's what my problem was, and it sounds like you have all the same symptoms I had. When I checked, my fluid it was all rank and crusty and had flaky bits in it.
On the road I never noticed I had a problem. On track though, as soon as it got up to temperature I had the same symptoms you're having.
I flushed the system through thoroughly (to get rid of all the flaky gunky rubbish) and then replaced it with some upgraded brake fluid.
Problem sorted.
#30
Posted 23 April 2014 - 01:06 PM
my brake fluid is 5 days old
#31
Posted 23 April 2014 - 01:20 PM
#32
Posted 23 April 2014 - 01:34 PM
Only happens once hot... on track or road also ?
Only under braking hard ? with no symptoms unless on brakes.
#33
Posted 23 April 2014 - 02:27 PM
Stuwy have you taken the pads out and checked them? I haven't had any problems on my 1144s and despite only having done 2 track days in them I haven't had any issues with them. Gave them a fair bit of abuse at Woodbridge as well.
Bearings should be easy enough to check if you whip them off. Though I wouldn't of thought they'd cause it only when hot. I take it the wobble is at all speeds on track or is it more prolific at higher speeds?
#34
Posted 23 April 2014 - 03:18 PM
#35
Posted 23 April 2014 - 03:19 PM
#36
Posted 23 April 2014 - 03:27 PM
Once it's cooled down does it disappear until up to temp again? - Either between sessions or at the end of the day on the drive home did it go?
Is the shuddering being felt through the steering wheel or through the seats and chassis?
#37
Posted 23 April 2014 - 03:38 PM
#38
Posted 23 April 2014 - 05:07 PM
#39
Posted 23 April 2014 - 06:30 PM
#40
Posted 23 April 2014 - 08:50 PM
Both discs and hubs are cheap. I think you should eliminate any of the causes by changing both.
