Does this work on Android these day?
Yerp.
Posted 14 July 2014 - 09:44 PM
Yerp.
Posted 19 July 2014 - 07:23 PM
Posted 20 July 2014 - 10:05 AM
Posted 20 July 2014 - 10:22 AM
Posted 26 May 2015 - 01:19 PM
Been looking into going with Harry's Laptimer on an old iphone4 I have.
General question. I assume you guys use the rear facing camera of the phone? If so does that mean when the phone's mounted on the rear window/harness bar you can't control the app via the touchscreen? What do you do, launch app the stick the phone on the holder? And does the screen stay on or can it go blank whilst its running so as to not display out of the rear window.. Or do you use the front facing camera?
The phone only has 16GB so I'd have to record at pretty low res I presume. And Was going to plug in an external mic to the phone to mount somewhere where there's no wind noise with roof off... Anyone done that?
Posted 26 May 2015 - 05:26 PM
My screen stays lit out the rear window. I select video and mount it and look through the rear window to line it up then set off. It starts recording as I pass the start finish straight.
I have a 64gb but a 20min session at 720p is about 1.7gb so it doesn't use it very quickly.
Posted 26 May 2015 - 05:33 PM
I use track addict on an iPhone 4 to sometimes clock lap times as it does that well. I find the video overlay isn't accurate though as the GPS built into the phone is too slow to be accurate. I think you need a better phone really. Mark what phone do you use for Harrys lap time?
Posted 26 May 2015 - 05:36 PM
Posted 26 May 2015 - 06:01 PM
Posted 26 May 2015 - 06:21 PM
I used strava at snetterton the other day ...that was quite fun
it knew all the corners and gave me average and top speed !
Posted 26 May 2015 - 06:32 PM
Posted 27 May 2015 - 10:55 AM
Can you use it just for the GPS data and export it so you can combine the data with video from another device?
I've used various GPS loggers in the past then used Dashware to overlay it onto video, like this:
Posted 27 May 2015 - 11:03 AM
Yes you can export the data with RaceChrono and Harrys Lap Timer (though with HLT I think it still has to record a video). Haven't tried with TrackAddict.Can you use it just for the GPS data and export it so you can combine the data with video from another device?
Posted 27 May 2015 - 02:55 PM
Cheers. Will have a play...
