Now That's A Better Working Height
29 replies to this topic
#21 Kieran McC
Kieran McC
  • 3,416 posts
Posted 21 August 2014 - 05:51 PM
Does yours spread the load across the cills ?
#22 PaulCP
PaulCP
  • 6,066 posts
Posted 21 August 2014 - 06:30 PM
Mine sits just inboard of the sills The one on eBay which shows a minimum width of 1400mm could be a tad too wide. Max width really should be the width of the main side jacking points plus 150mm. This way the main jacking point will sit dead centre on the support pad. TBH at £244, if it is a tad too wide taking it to a fabricator to cut it down and weld wouldn't cost much on top.
#23 VXT Tim
VXT Tim
    No it's not a Lamborghini!
  • 11,421 posts
Posted 21 August 2014 - 06:45 PM
What if you have a single garage, is it narrow enough to drive over, then extend the sill supports?
#24 PaulCP
PaulCP
  • 6,066 posts
Posted 21 August 2014 - 06:54 PM
You won't drive the VX over it. Mine is set at 120/130 ride height and needs to be about 1" higher to get the frame under. I use caravan levelling ramps to drive on to to get the extra height. It stores on its end though against the wall so takes up minimal room
#25 FLD
Posted 22 August 2014 - 01:48 PM
Be careful, the one in the link will be too wide, you need to go for the adjustable width version or get FLD to cut and weld the non adjustable one to the correct width. This is what Darcini did
EFA!
#26 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 22 August 2014 - 01:53 PM
  EFA!
Thanks for the offer FLD :D
#27 FLD
Posted 22 August 2014 - 02:05 PM
  EFA!
No problem.  Not mentioned my rates yet though :D
#28 Ebo100
Ebo100
  • 654 posts
Posted 22 August 2014 - 05:39 PM
Any chance of a close up photo of how the car sits on the ramp and maybe a shot looking from under the car?
#29 PaulCP
PaulCP
  • 6,066 posts
Posted 22 August 2014 - 06:12 PM
Doesn't really show what you are after. Will take more pics next time I use it which is likely to be in 2 weeks time after the French Frolic trip
#30 Darcini
Darcini
  • 2,508 posts
Posted 22 August 2014 - 08:37 PM
  EFA!
Don't worry, He's cheap. Very.
