Garrett Equipped Let Drivability - Opinions Please
#21
Posted 01 September 2014 - 06:32 PM
#22
Posted 01 September 2014 - 08:00 PM
#23
Posted 01 September 2014 - 09:45 PM
#24
Posted 02 September 2014 - 09:19 PM
#25
Posted 03 September 2014 - 12:09 AM
#26
Posted 03 September 2014 - 05:44 AM
That's interesting that you have a boost controller as I've been told By a lot of company's that I can't run one on std management, can't remember why now though........
Control of AFR?
#27
Posted 03 September 2014 - 04:02 PM
You just need to leave the standard boost solenoids plugged in electrically.
Pic is a bit messy as I had the dash apart when fitting.
#28
Posted 03 September 2014 - 05:06 PM
So does this smooth out power delivery on part throttle CraigyT?
#29
Posted 03 September 2014 - 07:41 PM
#30
Posted 03 September 2014 - 08:11 PM
Sorry,not sure what you mean by power delivery on part throttle? I would have thought that depended on how much you are pressing the pedal?
On a stage 4 turbo with the standard turbo (300bhp ish) it is fine when accelerating hard (full throttle) and obviously when off throttle, but when you need to balance the throttle (hold a steady speed/boost) it can dump the boost/boost/hic up/chatter, basically not be very smooth and controllable.
I find if I accelerate with the throttle say 30/40% open it gets to a certain point in the rev range when it just dumps boost momentarily causing a hiccup in the acceleration. The only way to circumvent that is to adjust the throttle.
The question is, with the Garrett is that the case or not?
#31
Posted 03 September 2014 - 08:32 PM
#32
Posted 03 September 2014 - 08:33 PM
#33
Posted 03 September 2014 - 08:35 PM
#34
Posted 03 September 2014 - 09:33 PM
#35
Posted 03 September 2014 - 10:13 PM
Ah I see. No that's not the case for me personally, it holds boost fine. Next time im out a drive I could film it I guess so you can see. Surely that would be down to boost control and not the actual turbo?
Yes...I would guess its the result of the recirculation (internal dump) valve just being open or shut and not being able to modulate that finely enough?
The issue is that at oem levels of boost its is fine, and at 230 -250 bhp (stage 2/3). It seems to be at stage 4 levels it becomes an problem.
Edited by P11 COV, 03 September 2014 - 10:15 PM.
#36
Posted 03 September 2014 - 10:20 PM
#37
Posted 03 September 2014 - 10:27 PM
Me too. Pleased to read i'm not alone. Fantastic on full throttle thoughI've only had my stage 4 for a short time but this is exactly the issue I have or should say had until the chargecooler went! You cannot moderate part boost and hold it. Joe
Edited by YorkieAndrew, 03 September 2014 - 10:29 PM.
#38
Posted 03 September 2014 - 10:42 PM
#39
Posted 04 September 2014 - 07:03 AM
Never had this problem on my Garrett - Nissan cars. Sounds like you guys have a boostcontrole problem.
The blow-off-valve will not be the problem. When on partial throttle accelerating the bov will be shut. It only opens when vacuum is seen in the intake manifold (so also when cruising, no boost).
You might have a problem with higher boost levels and the way it is controlled by the tiny flapvalve/wastegate in the turbo. Hence why people use an external wastegate. Larger exit so better and more steady boostcontrol. Adding an electronic boostcontroller to an EW will make things even better.
My greddy EBC on my GT2871R did very nice things in ways of smoothness.
@CraigT: What 2871 housing did you run? Had a .86 on my sr20det and that thing was an on/off switch at 4500 rpm. Not a thing I would want on a VX
#40
Posted 04 September 2014 - 08:06 AM
