#21
Posted 18 September 2014 - 07:21 PM
#22
Posted 18 September 2014 - 07:44 PM
Recomended is 120mm front, 130mm rear
By who?
#23
Posted 18 September 2014 - 09:37 PM
#24
Posted 19 September 2014 - 11:39 AM
Edited by Nev, 19 September 2014 - 11:54 AM.
#25
Posted 19 September 2014 - 12:05 PM
Anything lower than 140f/140r will make handling worse unless you buy or make expensive bits. I have no idea why you run at such a low setting Martin, but I would seriously consider raising your ride height and then get your toe in settings adjusted (which is easy and cheap to do). You will notice a huge improvement, particularly on bumpy surfaces.
Because the VX looks stupid on tds if you don't lower it ?
Your car handles great. People have told you it handles great.
If you sacrifice a -bit- of handling because of that low ride (you might not even be able to tell?), there will still always be somebody else with a stupidly low car of similar spec you can have fun on track with (me for a start!)
#26
Posted 20 September 2014 - 12:22 AM
Anything lower than 140f/140r will make handling worse unless you buy or make expensive bits. I have no idea why you run at such a low setting Martin, but I would seriously consider raising your ride height and then get your toe in settings adjusted (which is easy and cheap to do). You will notice a huge improvement, particularly on bumpy surfaces. Setting the toe in on the front and rear can be easily DIY'ed, just look on YouTube to see how.
If you have seen Martins car on track you will know it handles very well, theres not much that can keep with him on track. I would imagine Martin is also happy with how it is on the road given that he has been using it for years on the road too. Also I do not recall noticing that it looks too low, pretty much the same as most other VX's used regularly on track.
Edited by P11 COV, 20 September 2014 - 12:23 AM.
#27
Posted 20 September 2014 - 03:32 AM
Same here, got photos of it somewhere from track sessions, looked same height as mostIf you have seen Martins car on track you will know it handles very well, theres not much that can keep with him on track. I would imagine Martin is also happy with how it is on the road given that he has been using it for years on the road too. Also I do not recall noticing that it looks too low, pretty much the same as most other VX's used regularly on track.Anything lower than 140f/140r will make handling worse unless you buy or make expensive bits. I have no idea why you run at such a low setting Martin, but I would seriously consider raising your ride height and then get your toe in settings adjusted (which is easy and cheap to do). You will notice a huge improvement, particularly on bumpy surfaces. Setting the toe in on the front and rear can be easily DIY'ed, just look on YouTube to see how.
#28
Posted 20 September 2014 - 07:42 AM
What bits?
#29
Posted 20 September 2014 - 07:46 AM
#30
#31
Posted 20 September 2014 - 07:49 AM
Uprights
I must have a magic VX then
#32
Posted 20 September 2014 - 07:53 AM
Benny's magic touchI must have a magic VX thenUprights
#33
Posted 20 September 2014 - 07:55 AM
Jez and Bennys magic touch
EFA
Dynamo and his lovely assistant
#34
Posted 20 September 2014 - 05:22 PM
Things like new (off the shelf) uprights with raised hub centres, different steering arms to reduce the bump steer, spacers at the bottom of new longer lower ball joints to raise the roll centres back up. Or, if you have the software/knowledge how to calculate what you desire from and fabricator who can do it at a good price, you could design and fab new wishbones with different uprights entirely - there are a couple of VX'es like this as you'd need a lot of money, so not really applicable for most people I suspect.What bits?Anything lower than 140f/140r will make handling worse unless you buy or make expensive bits.
#35
Posted 21 September 2014 - 09:46 AM
The ride height was set up by back on track along time ago and then by Cliffie when the gaz monos went on, but he set it up the height it had been, so its been this way for at least 6 years.
I don't think it looks particularly low compared with others. Sure it touches down a bit but we don't have that many speed humps round here so generally not a problem.
The car has always seemed to handle pretty well, and thanks for the compliments on the car being quick, whats interesting was all the people complimenting me and the car are the buggers that are generally quicker than me (maybe its a ploy).
Will see how it is in action at Snetterton tomorrow.
Martin S
#36
Posted 21 September 2014 - 11:05 AM
Martin S
And Jez will have set it lower than 140/140 but then again WTF does he know
#37
Posted 21 September 2014 - 12:51 PM
#38
Posted 21 September 2014 - 12:59 PM
#39
Posted 21 September 2014 - 01:13 PM
No change when I had the 17's all round, but they were gone within two weeks and I was back on my 17 and 16 combo.
Martin S
#40
Posted 22 September 2014 - 08:23 AM
