Intermittent Rotational Knocking Sound From O/s/r Side
trans
22 replies to this topic
#21 Egor
Egor
  • 103 posts
Posted 26 October 2014 - 03:57 PM
Engine mounts?
 Absolutely Solid , i've got inserts in the mounts  :)
#22 Egor
Egor
  • 103 posts
Posted 26 October 2014 - 04:14 PM
Castle nut is the large nut with split pin through it behind centre of wheel
 If the castle nut was loose  , then bearing would be noisy all the time and then play in the wheel guaranteed .
 Mine has no constant noise , passenger rear side has just a very little play .
Anyone north/west could have a drive the car and indentify the sound ?
#23 Egor
Egor
  • 103 posts
Posted 31 October 2014 - 11:18 PM
 Cheers , thanks very much for all replys . :)
Now interesting part , the knock was from O/S/R track rod end  ... car was in the garage for the GEO recently  and these guys didn't tight the the nut proper , left it quarter turn loose   :D  the funny part  , when i checked for a play it was ok , only position it would knock when the car on the 4poster ramp and you push the car up slightly using  right engine mount bracket .
