What Is The Best Coilovers To Fit For Normal Road Use
31 replies to this topic
#21 siztenboots
Posted 30 October 2014 - 12:40 PM
true but that was what circa 2000 , things have moved on
#22 vocky
Posted 30 October 2014 - 01:59 PM
nothing wrong with Quantums Mr Slindy  :P
note the crossed out bit :P
too soon to determine if they are due a good rant yet :lol:
I always enjoy reading your rant posts, so keep them coming  :D
#23 vocky
exactly what I told someone the other day
#24 siztenboots
Posted 30 October 2014 - 02:12 PM
stuff like Magnetorheological fluid , that lets you vary the viscosity with a magnetic field
#25 fezzasus
Posted 30 October 2014 - 02:15 PM
Except that's only really used in big saloons with sports buttons. Never seen that in a sports application, mostly (I suspect) because if the valving is designed correctly then there is no need to modify the viscosity of the fluid. One that changes as a response to fluid temperature to keep viscosity constant however, may be interesting.
#26 slindborg
Posted 30 October 2014 - 02:27 PM
How do Aston and the like do their stiff suspension settings with buttons?
button off = stiff, button on = who put scaffold poles instead of dampers :lol:
#27 fezzasus
Posted 30 October 2014 - 02:43 PM
button on = springs no longer matched to damper response.
#28 AliV6
AliV6
  • 20 posts
Posted 30 October 2014 - 02:56 PM
Few questions Re. the Exige Set up:
  • How much is the Exige set-up?
  • Assume purchase from Lotus? or Another source?
  • Is it a direct replacement, no modifying needed?
Cheers
AR
#29 Rosssco
Rosssco
  • 4,185 posts
Posted 30 October 2014 - 03:25 PM
  • £200 - £400 per set typically
  • Yes, or they come up used in various conditions
  • Direct replacement. Static ride height slightly bigger.
Cheers
AR
#30 G-Bob
G-Bob
    Embarrassing VX's in an MX5
  • 8,256 posts
Posted 30 October 2014 - 03:42 PM
If you are going to buy exige or 111r stuff then register on seloc and get some lightly used stuff. I got some a couple of years ago with 2000miles on them for £220.
#31 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 30 October 2014 - 04:57 PM
Come on Slind, you of all people must know that these buttons are - half the time - a pure placebo with no real effect. Or a time-limited effect before resorting to 'automatic' damping
#32 lagerwk
lagerwk
  • 49 posts
  • Interests:Rugby, Cricket, F1, MotoGP, Moutain Biking
Posted 07 November 2014 - 03:13 PM
So if you want to refurbish your Bilsteins  The standard cost is £80.00 each + vat which includes all internal parts and labour. If any cost is likely to be incurred they will let you know before we proceed, below their address:
[color=rgb(89,89,89);font-family:Calibri, sans-serif;font-size:11pt;]7 Vitruvius Way | Meridian Business Park | Leicestershire | LE19 1WA | England [/color]
[color=rgb(89,89,89);font-family:Calibri, sans-serif;font-size:11pt;]Phone:+44 (0) 116 2819015 |  Fax:+44 (0) 116 2899021 | [/color]
[color=rgb(89,89,89);font-family:Calibri, sans-serif;font-size:11pt;]E-mail: [/color][color=rgb(31,73,125);font-family:Calibri, sans-serif;font-size:11pt;]david.masters@kruppbilstein.co.uk[/color][color=rgb(89,89,89);font-family:Calibri, sans-serif;font-size:11pt;] [/color][color=#000000;font-family:Calibri, sans-serif;font-size:11pt;] [/color][color=rgb(89,89,89);font-family:Calibri, sans-serif;font-size:11pt;]|Internet: [/color][color=rgb(31,73,125);font-family:Calibri, sans-serif;font-size:11pt;]www.bilstein.de[/color]
