Fitting Universal Splitter Help Please
42 replies to this topic
#21 MartinS
MartinS
  • 5,173 posts
  • Interests:Track days
    Pubs
    Sausages
Posted 25 January 2015 - 08:26 AM
I'm doing corner splitters only that are mounted onto the end parts of the seat leon splitter.
The splitter part will be thin steel (only done in strong card at this time) bolted to the seat leon part then all held on to the car using plastic scrivets so that should it ever find itself (again) in the gravel it will get pulled off easily.
Martin S
#22 CHILL Gone DUTCH
Posted 25 January 2015 - 08:41 AM
I think I would rather it pulled of rather than risking the clam
#23 MartinS
MartinS
  • 5,173 posts
    Pubs
    Sausages
Posted 25 January 2015 - 10:56 AM
That's why mine will be smaller than say the Robin one and only attach via scrivets to the clam. Had a couple seat leon's ripped off in the past and no damage so far.
If a hole does get bigger, its easy to sort and out of sight anyway.
I'm just doing subtle side splitters only as have ground clearance problems.
Martin S
#24 CocoPops
CocoPops
  • 17,182 posts
Posted 25 January 2015 - 11:05 AM
Thin steel? Like a knife blade mounted to th front of the car :unsure:
#25 hairy
hairy
    Moonlander
  • 6,034 posts
Posted 25 January 2015 - 11:10 AM
no cutting remarks
#26 MartinS
MartinS
  • 5,173 posts
    Pubs
    Sausages
Posted 26 January 2015 - 08:40 AM
Lee has steel all over his car as do others and I have steel winglets at the rear I was trying to match up to.
Agree there is a knife like element to it though?! Will look into other possible materials. Any ideas, something strong, 2-3mm, easy to cut and bend.
Martin S
Edited by MartinS, 26 January 2015 - 08:41 AM.
#27 Mopeytitan
Mopeytitan
  • 1,908 posts
    My dogs (love my dogs).
    F1.
Posted 26 January 2015 - 08:51 AM
Martin S
i would recommend using 26 guage ally. steel will be really heavy. if you send me dimensions i can get some made up for you.
Al
#28 techieboy
Posted 26 January 2015 - 08:54 AM
Just fit some rubber edge trim to the leading edge. Good enough to get through the SVA pedestrian tests.
#29 MartinS
MartinS
  • 5,173 posts
    Pubs
    Sausages
Posted 26 January 2015 - 09:13 AM
Pretty sure carbon fibre would act6 as a pretty good cutting tool as well and yet is very popular. Want shapr lines as not a fan of the plywood look.
Martin S
#30 FLD
Posted 26 January 2015 - 09:16 AM
Yeah, its one I made a while ago.
You ever going to make anymore?
Hadn't planned on it since the mould for the base element went to the tip a few years ago!  :D
I guess you'll have to make stuey an offer he can't refuse.
#31 FLD
Posted 26 January 2015 - 09:17 AM
Looking good!
YOu happy with it, fit etc?
#32 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 26 January 2015 - 01:15 PM
been on for ages now, also looks a bit erm bent since I went off at Snett
#33 FLD
Posted 26 January 2015 - 01:24 PM
 Oooops!
#34 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 26 January 2015 - 01:36 PM
 Oooops!
  its ok, just needs to be taken off and reseat the rubber thing
#35 -Dab-of-Oppo-
-Dab-of-Oppo-
    Cuntpuffin
  • 3,646 posts
Posted 26 January 2015 - 05:12 PM
An old thread.... But MBES2 can you please tell me where you got those turnbuckle bolts from? I'm considering a similar splitter and fixing method, but the only turnbuckle's with nut and bolt ends I can find are £20 each
I can make you up a set of custom length carbon fibre ones if you want? I used a fairly long one as a spoiler support but they would work just as well for a splitter. I think Leevx2.2 has some fitted.
#36 -Dab-of-Oppo-
-Dab-of-Oppo-
    Cuntpuffin
  • 3,646 posts
Posted 26 January 2015 - 05:16 PM
I was right he has -
:wub:
Edited by -Dab-of-Oppo-, 26 January 2015 - 05:18 PM.
#37 Benzola
Benzola
  • 353 posts
  • Interests:All things fast and powered by petrol!
Posted 27 January 2015 - 12:17 AM
You sir a gentlemen and a VX scholar! Yep, I'll DEFO have a pair of them please mate! Just drop me a line and I'll pay pal over some 'moola-to-ya-coola'. Benzola :-)
Edited by Benzola, 27 January 2015 - 12:21 AM.
#38 Renny
Renny
  • 1,171 posts
Posted 27 January 2015 - 11:17 AM
I have these on my wing and love them. I used a tap washer between the metalwork and car. I have a black car so not noticeable but adds as a slight cushion.
#39 Benzola
Benzola
  • 353 posts
Posted 28 January 2015 - 12:27 AM
I'm doing corner splitters only that are mounted onto the end parts of the seat leon splitter. The splitter part will be thin steel (only done in strong card at this time) bolted to the seat leon part then all held on to the car using plastic scrivets so that should it ever find itself (again) in the gravel it will get pulled off easily.   Martin S
You might want to consider a pair of these Martin (bit better than stiff card, and no hassle of building your own): http://www.ebay.co.u...74476224&_rdc=1 Before deciding to go for a big splitter I considered same solution as you're considering. By 'eyeballing' it I recon these might be the ticket for you? Plus they're a good price and seller seems like a top lad who 'may' tweak-to--fit. Listing on fleabay has ended but 'contract seller' (he got back to me). Let us know how you get on. Cheers. Benzola.
#40 MartinS
MartinS
  • 5,173 posts
    Pubs
    Sausages
Posted 28 January 2015 - 08:21 AM
Note how Lees has a metal splitter, waaaay bigger than anything I plan. No rubber edging just a great big air gathering scythe!
Martin S
