Fuel Pump Replacement
#21
Posted 08 January 2015 - 07:24 PM
#22
Posted 08 January 2015 - 11:57 PM
#23
Posted 09 January 2015 - 08:07 AM
#24
Posted 09 January 2015 - 09:12 AM
Walbro 255 should be capable of a lot more than 310...
(Only if you up the pressure above stock, most pumps will have a hard time)
#25
Posted 10 January 2015 - 06:38 AM
The walboro pump is horrid.
Fit a new OEM one.
#26
Posted 10 January 2015 - 12:10 PM
my walbro pump is noisy as fcuk.. wines louder then the SC sometimes...
#27
Posted 10 January 2015 - 01:01 PM
Yep😠😠, I knew there was another job i needed to do this wintermy walbro pump is noisy as fcuk.. wines louder then the SC sometimes...
#28
Posted 10 January 2015 - 06:18 PM
My brand new (last year) OEM one, in new canister, is completely silent. And is fine for 265hp.
comparing old OEMs to new (even though they are shitty) is not a good comparison.
#29
Posted 10 January 2015 - 06:26 PM
Yeah, I have that problem with the missus in the car.... *awaits punch*my walbro pump is noisy as fcuk.. wines louder then the SC sometimes...
#30
Posted 10 January 2015 - 11:50 PM
Chris is on about running 350+ bhp so the Oem is not good enough for the job. My walbro 455 fuel is a bit louder but you soon forget about the noise after a while.My brand new (last year) OEM one, in new canister, is completely silent. And is fine for 265hp. comparing old OEMs to new (even though they are shitty) is not a good comparison.
#31
Posted 11 January 2015 - 06:00 PM
#32
Posted 11 January 2015 - 08:38 PM
He uses a different, quiet, pump in his modifications.
#33
Posted 11 January 2015 - 10:46 PM
#34
#36
Posted 14 January 2015 - 10:38 AM
True, but it is the installation that causes most of the noise issues with simple Walbro pump swaps.
Don't forget a lot of these Walbro installations also have fuel starvation problems when cornering, clearly that is a disfunction of the refill system which is pump powered.
The OE pumps seem to be Ok up to 280 ish depending upon rail pressure, if you are close to maxing the pump out you could try to measure the voltage at the pump itself, if under 12.3-12.5 a heavier cable direct from the fuse box should give a significant increase in output, about 5-10% that may get you out of labour intensive pump swap.
#37
Posted 14 January 2015 - 10:49 AM
oem pump fine as a low pressure lift pump , then a bosch 044 for your application 3 - 4bar
or you could adapt it and go returnless
#38
Posted 14 January 2015 - 04:10 PM
As quick fix I rewired my old OEM pump directly from alternator/startermotor with a thicker cable + relay. => 14.4 volt and still OK-ish for my mild Harrop build with 3.0 bar rail pressure.
(The starvation in left handers is a totally different fuel problem and too big a pump is not helping here. And heats up the fuel...)
Edited by Exmantaa, 14 January 2015 - 04:11 PM.
#39
Posted 14 January 2015 - 07:15 PM
The starvation is caused by the educter pump which is rather ironic as it's job is to achieve just the opposite
It also causes a lot of the noise with a swapped Walbro install.
