its not cured the slightly floppy feeling at the front,
FNNNNAAAAAAAAAAAAAAAAAARRRRRRRRRRRRRRRR!
Posted 26 February 2015 - 01:47 PM
Posted 27 February 2015 - 05:52 PM
Shock horror, fat americans that can't even fit in the fkucking thing and think anything smaller than a focus is a shoe, think the 500 is crap! Got the little sh1t box booked in on Monday... taking somebody out on a road test so they can hear, diagnose and fix whatever is knocking at the front! Guessing the top mounts!! Very much like a creak when going over speed humps. Thankfully I believe they are covered by warranty. Anybody know if you can get vented front discs as a direct fit or won't they fit under the calipers, mine are warped as fcuk now.It's not necessarily my opinion, but I found this handy guide to the cute little Fiat 500 online: Fiat 500s are tough: http://www.dailymail...tect-crash.html Fiat 500s are good: https://itscrap.word...12/26/fiat-500/ Fiat 500s are fun and nippy: http://www.motoringr...hdog-1107954951 Fiat 500 and its legendary reliability: http://www.foxnews.c...t-reliable-car/ The place for Fiat 500 Registers: http://fiat500club.org.uk/home/
Posted 27 February 2015 - 06:38 PM
Posted 27 February 2015 - 07:02 PM
Posted 27 February 2015 - 07:21 PM
Posted 27 February 2015 - 07:28 PM
Posted 27 February 2015 - 07:32 PM
Posted 28 February 2015 - 06:43 AM
Posted 28 February 2015 - 08:19 AM
It's both at times... I think its either the ball joints or front arm bushes which can be replaced separately with chav white line granite items for less than wishbonesSure... when you say "pull the car around", do you mean vague steering or almost like tramlining?
Posted 02 March 2015 - 09:24 AM
He said most likely ball joints but that he would expect it to knock as wellIt's both at times... I think its either the ball joints or front arm bushes which can be replaced separately with chav white line granite items for less than wishbonesSure... when you say "pull the car around", do you mean vague steering or almost like tramlining?
Posted 02 March 2015 - 11:09 AM
Thats what I'm leaning to, too.
Oh and the fcuking thing started knocking its back end (fnaaarrrrrrr © FLD) this morning... damn it.
Posted 02 March 2015 - 01:18 PM
Quality Italian components at the sound of it. Works well for a short period of time, then can't be bothered.
Posted 02 March 2015 - 01:35 PM
gonna see if I can get some bushes made up to replace the rear damper parts as I CBA to spend money on new dampers that will fail like this again
Posted 02 March 2015 - 02:19 PM
Posted 02 March 2015 - 03:47 PM
nice. I cheated and drilled a hole in each cup to let the water drain away. Although I'm very very confident that its not water collecting in the cup that causes the problem as its got to pass two threaded fastners, around a double rebated interface to the bearing and then into the bearing. Its more than likely a problem from road spray... imho of course.
Posted 14 March 2015 - 09:05 AM
Verdict in... well sort of... they can hear it and reproduce it but aren't 100% sure what it is, so they are replacing the dampers/struts, top mounts, top mount cups and even throwing in the caps to keep the water out of the cups... under warranty
Well, was in India with work last week, so left Fiat with my spare key and they kindly popped over, got the car, changed all of the above and returned it...
There is good news and bad news:
Good news - You never know how sh@gged up your suspension is until you have it replaced... feeling lovely and tight now.
Bad news - The noise that prompted them to change the suspension is still there - no change at all!
Off to Fiat this morning to pick up my key and discuss!
They will surely have checked all ball joints, drop links etc., etc., when they dismantled it all, so I am beginning to think it is not suspension related... would there be enough flex in the body when going over speed humps to cause the arch liners to flex and make a creaking noise when rubbing against the body or am I talking crap? The sound is only present when going over big humps, where the suspension gets pretty much fully compressed and un-compressed... any other thoughts?
Posted 14 March 2015 - 09:08 AM
Posted 27 April 2015 - 09:04 PM
Posted 28 April 2015 - 08:50 PM
Posted 30 May 2015 - 03:24 PM
Add me to the register, just bought an 09 Abarth Esseesse
