Brake Bias Valve
56 replies to this topic
#41 The Batman
Posted 30 January 2015 - 11:17 AM
The new motor has servo delete with bias valve interior controller and duel master cylinder The feel you get through the pedal is awesome
#42 Exmantaa
Posted 31 January 2015 - 10:05 PM
We need a pic of that!!
#43 FLD
Posted 01 February 2015 - 11:55 AM
:yeahthat:
#44 Bargi
Bargi
  • 4,483 posts
Posted 01 February 2015 - 05:31 PM
If it makes any difference...
When I drove Lees the longer pedal travel is def noticeable so if you plan to heel toe then you're going to need either a different MC, Dual MC, etc or move your pedals around.
#45 chris_uk
Posted 01 February 2015 - 09:52 PM
i don't have problems with heel toe.. mine is the same as lees isn't it?
#46 The Batman
Posted 01 February 2015 - 09:59 PM
:yeahthat:
What ya want pictures of? Pedal box Master cylinders Bias valve ?
#47 Bargi
Bargi
  • 4,483 posts
Posted 01 February 2015 - 10:41 PM
dunno mate, I just found pedal travel was down quite a bit more and I'd need to stand on the brake like a ballet dancer to get my heel high enough to make the accelerator.
Edited by Bargi, 01 February 2015 - 10:42 PM.
#48 kipper
kipper
  • 2,364 posts
    Smoking various types
    of fish.
Posted 01 February 2015 - 11:29 PM
That's strange, in my setup there was very little difference in pedal travel, with the two pots installed at the rear.
After the first road trial,  there was a massive pedal difference, looked like a failure.... and I would have to get a larger bore, compound master cylinder. However, found a good re-bleed of the system cured the ill's...
#49 Bargi
Bargi
  • 4,483 posts
Posted 01 February 2015 - 11:35 PM
Maybe his fluid needed changing then :D
#50 SteveA
SteveA
  • 9,159 posts
Posted 02 February 2015 - 05:11 PM
The accelerator can be adjusted, someone on here posted a guide up a while back.
#51 FLD
Posted 03 February 2015 - 06:10 PM
:yeahthat:
All of those please!
#52 The Batman
Posted 03 February 2015 - 06:24 PM
Will do when I get a min Operation kitchen is underway at the moment!
#53 FLD
Posted 03 February 2015 - 06:25 PM
thumbsup
#54 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 04 February 2015 - 09:55 PM
You need to find two sets of pads that will work well together though. I tried loads of different pads and found a lot of the time the rears would lock first. Ended up using Pagid RS14 pads on the front and Pagid RS42 (not so good) on the rear to even it up. Works well and allows you to be confident on the brakes. CLRc6 front and Rc5 rear may work as well but didn't test that combo.
George just to confirm that you use four pots front, two pots rear, with this combo?
Was originally planning on using the above combo with standard system so happy to use the same again with this 4 then 2 pot setup if so.
G
#55 GeorgeBC
GeorgeBC
    Needs a cheaper hobby
  • 3,138 posts
Posted 04 February 2015 - 10:25 PM
Yes I wouldn't run anything else now. You have to be so careful as I found some pads dangerous. With only four pots on the front nearly had me running into the back of two people on the highland hoon as the fronts would lock too easily in the damp/wet.
#56 GeorgeBC
GeorgeBC
  • 3,138 posts
Posted 04 February 2015 - 10:26 PM
Also Pagids seem to last twice as long as Carbon Lorraine and about 10-15 times as long as Mintex lol
#57 Graeme Lambert
Graeme Lambert
  • 5,543 posts
Posted 05 February 2015 - 07:44 AM
Sounds good mate thanks for confirming.
