Misfires At 2000Rpm
Posted 03 May 2015 - 08:41 AM
Posted 03 May 2015 - 09:14 AM
Posted 03 May 2015 - 09:31 AM
Posted 03 May 2015 - 09:38 AM
Posted 03 May 2015 - 09:39 AM
Think the question was less about codes and more about the way having a scangauge plugged in with refresh rate too high causing issues.Scan gauge or other obd reader plugged in?
Posted 03 May 2015 - 09:41 AM
Ahhh! It does it even with nothing plugged in.Think the question was less about codes and more about the way having a scangauge plugged in with refresh rate too high causing issues.Scan gauge or other obd reader plugged in?
Posted 03 May 2015 - 09:44 AM
Yes I do have a Dutch map. I'm on about my 5th map from Peter based on log files I've sent over to him. I've done several fuel learns but even holding the car on the rolling road at 2000rpm and gradually adjusting the fuelling and ignition specifically for the cell being used at the time does not get rid of the misfires. Peter and my tuner are now of the opinion that it is not a tune based problem.So you have the Dutch ecu map? If so do a log file and send it to Peter. Have you done a fuel learn? Again if not do one and smooth it before saving to the permanent ecu. I though I'd don't mine properly but I hadnt. Chill helped me set the car up and while I didn't have any issues like your having the car runs much smoother and cleaner now.
Posted 03 May 2015 - 09:52 AM
Posted 03 May 2015 - 09:55 AM
Edited by CHILL Gone DUTCH, 03 May 2015 - 09:57 AM.
Posted 03 May 2015 - 10:00 AM
Posted 03 May 2015 - 10:05 AM
Posted 03 May 2015 - 10:17 AM
Fuel pump - I believe it is the standard pump, though this is confusing because the access hatch has been widened as per the guide on here. I cleaned the pump filter and refitted it.
By the sound of your specs, you're at stage 3 or higher. (which is dangerous area for a standard pump)
Lift that hatch and look what you have, and see if there are any damages to the hosing.
The hatch has been made for a reason. Somebody did something, and you'd better find out what exactly.
Posted 03 May 2015 - 10:39 AM
Does the eml or any faults occour at the same time as the misfire ?
No, no EML occurs and no codes are reported.
Currently on the standard stage 2 pulley and lower than standard compression so the standard pump should be fine.
It will be replaced before I reduce the pulley size, as will the exhaust, but I'm trying not to throw money at something that is currently not working properly.
Googling the numbers on the side of the pump didn't return any relevant hits.
Surely the pump is either working or it isn't? It's always just pumping the same amount of fuel, if it can supply enough for full boost, why would it be causing a problem at 2000rpm and hardly any load? The same goes for the filter and send lines. Perhaps if the return line was kinked or regulator was dodgy it might be chucking in far too much/little fuel but on the rolling road we were getting reasonable AFRs through a wideband but still getting a misfire.
Posted 03 May 2015 - 10:48 AM
I can't remember who it was exactly on here (not so long ago), but also had weird problems, which were pump hose related.
Lifting the pump to take a look costs nothing, and by the huge list of all the other things you allready checked, this is what my gutt feeling is telling me.
The pump with number 25226034 / 0171-1 is oem (NA).
Posted 03 May 2015 - 10:50 AM
Posted 03 May 2015 - 11:29 AM
Posted 03 May 2015 - 12:08 PM
You already changed/swapped a lot, so what remains of the original?
Did it have the misfire pre-SC conversion initially? I guess not?
If no then I'd tak a very good look at the state and quality of the loom modifications that have been done for the SC.
The 'left un-connected' grounds and such seem to indicate that the initial SC conversion was perhaps not done with too much attention to detal. Perhaps one of the injector wires is only so-so connected/extended..
Or scrounge up a different 'known good' harness and convert that for the SC and install on the car.
You'd need to hook up a scope or signal analyser to various lines, but it smells like an interference or bad connection issue that rears it's head at certain frequencies.
Posted 03 May 2015 - 12:16 PM
This is the sort of thing I expect it to be.
I bought the car already converted and it has always had the problem during my ownership. The previous owner didn't do the conversion, I believe it was the chap before him.
Reckon it is worth getting an auto electrician to take a closer look at it? I can use a multimeter, but don't have access to a scope or know what to look for.
Posted 03 May 2015 - 12:17 PM
I've just had the pump out in the last hour, the number is:
25236034
0171-1
Any idea of what else to look for whilst I've got it apart? None of the internal hoses are visibly split or damaged.
Bing (1)
