Misfires At 2000Rpm
#41
Posted 07 August 2015 - 11:15 AM
#42
Posted 07 August 2015 - 11:16 AM
Wideband is reading 14.7:1 AFR during the stuttering so not sure what OBD tuner doing a learning session is going to change - surely it will also be seeing stoich and as such make very little change to the fuel table? - unless the learning session does something other than just write fuel adjustments that is.
I'll do another learn session over the weekend.
I'll take a screenshot when I get home this evening.
#43
Posted 07 August 2015 - 11:19 AM
Also get a logging session done trying to capture the stutter
I've got logs from a couple of months ago, but I'll capture a new one for you to take a look. Peter has cast his eye over the old stuff quite a bit and hasn't seen anything telling.
Also I notice that the car behaves really oddly when I dip the clutch and blip the throttle from very low revs. i.e. cruising in 3rd, brake to slow down, dip clutch, revs drop to 1kish, blip throttle and it just splutters instead of revving. Works totally fine at higher rev ranges.
#44
Posted 07 August 2015 - 11:23 AM
Edited by CHILL Gone DUTCH, 07 August 2015 - 11:23 AM.
#45
Posted 07 August 2015 - 11:24 AM
#46
Posted 07 August 2015 - 11:46 AM
As the moment I'm using the wideband completely separately from the ECU so they are not linked. Did all of my wide open throttle tuning in the rolling road manually adjusting the fuel and ignition cells. I'll take a look at the trims later.Recently been helping soMebody else who got stutters after using his wideband for full throttle mapping Have you re calibrated it ? Try doing a low rev fuel relearn using the fuel learn ( not wideband ) and might be a good idea to check the input settings of the wideband and re calibrate it
#47
Posted 08 August 2015 - 11:14 AM
https://drive.google...iew?usp=sharing
Link with the latest read from the ECU showing fuel trims.
No logging yet, but will get some done this afternoon, do a learn and then log again.
#48
Posted 08 August 2015 - 11:19 AM
this file has a quick log with the car in neutral misbehaving when I try to hold it at a constant throttle pedal position and also shows the laggy response of the engine when the throttle is blipped from idle.
#49
Posted 08 August 2015 - 12:06 PM
Edited by CHILL Gone DUTCH, 08 August 2015 - 12:06 PM.
#50
Posted 08 August 2015 - 12:20 PM
Yes:
0-25% 23-35% 35-70% 70-100%
0-1800rpm 1.2 0.6 -0.8 -0.3
1800-2200rpm 3.9 1.4 0.0 -1.2
2200-2600rpm 2.2 -0.2 -0.1 -0.4
2600-3800rpm 1.6 0.1 0.4 0.2
3600-limiter 0.6
#51
Posted 08 August 2015 - 04:44 PM
Edited by CHILL Gone DUTCH, 08 August 2015 - 04:44 PM.
#52
Posted 08 August 2015 - 04:47 PM
#53
Posted 08 August 2015 - 05:12 PM
#54
Posted 08 August 2015 - 05:46 PM
try this at let me know if its any better
#55
just put it straight on the car and try it
#56
Posted 09 August 2015 - 09:52 AM
#57
Posted 09 August 2015 - 10:09 AM
#58
Posted 09 August 2015 - 10:39 AM
#59
Posted 09 August 2015 - 10:48 AM
Hard to say subjectively felt a little better but certainly still has a problem.Was it any better ??
#60
Posted 09 August 2015 - 10:49 AM
