Misfires At 2000Rpm
#21
Posted 03 May 2015 - 12:25 PM
#22
Posted 03 May 2015 - 12:27 PM
It might be worth having a look for corrosion of the engine loom electrical connections, especially the new injector plugs. Get some good quality electrical contact cleaner and spray each plug, including TB, loom of doom and ECU.
#23
Posted 03 May 2015 - 12:50 PM
https://drive.google...VzZF&authuser=0
Pic of spark plug someone asked for
https://drive.google...iew?usp=sharing
Pic of fuel pump
I'll go out and buy some contact cleaner. I've tried a bucket load of WD40 on the loom of doom but perhaps that couldn't cut it.
Does anyone have a fuel pressure gauge with the correct fittings I can borrow to rule out the pump/fuel lines?
#24
Posted 03 May 2015 - 03:03 PM
#25
Posted 04 May 2015 - 10:01 PM
#26
Posted 05 May 2015 - 08:11 AM
When I replaced the valves they all moved very nicely in the stems.
#27
Posted 07 May 2015 - 11:22 AM
No corrosion spotted on the injector plugs, loom of doom, TB or ECU.
I've now sprayed each with proper contact cleaner.
The problem persists.
Can anyone recommend an auto electrician in the Warwickshire area who could take a look for me?
#28
Posted 07 May 2015 - 02:24 PM
#29
Posted 07 May 2015 - 02:36 PM
Do you still have am EGR fitted?
No and it is disabled by OBD tuner.
#30
Posted 07 May 2015 - 09:22 PM
#31
Posted 07 May 2015 - 09:33 PM
#32
Posted 08 May 2015 - 03:08 PM
#33
Posted 08 May 2015 - 07:06 PM
#34
Posted 08 May 2015 - 07:21 PM
#35
Posted 28 May 2015 - 02:27 PM
I've just been and had a look at techieboy's car and he's got spacers between his fuel rail and head.
Did a quick search and there seems to be a bit of disagreement about whether they're needed or not. Can anyone confirm this?
The car came with what I think were VX220T injectors (long thin shape), it now has Siemens 60lbs injectors which are the same size and shape.
#36
Posted 28 May 2015 - 05:08 PM
fitting the grey injector spacers and the alloy fuel rail spacers with the Siemans injectors means that the fuel injector loom plugs fit much better, otherwise you can sometimes get a bad electrical connection
#37
Posted 28 May 2015 - 05:38 PM
Darn. So unlikely to be that then.
#38
Posted 07 August 2015 - 10:29 AM
Still having this problem.
Fitted a Walbro 255 pump, full 3" tullett exhaust with HJS cat, a wideband O2 sensor and 2.8" pulley.
Vocky came to time up my cams in case they were slightly off as power seemed pretty low when I had it on the rollers (276bhp - was expecting around 300).
Seems to have more power than before the cam timing was done but still stutters and misfires like a pig around 2k.
Any more ideas????
#39
Posted 07 August 2015 - 11:08 AM
#40
Posted 07 August 2015 - 11:12 AM
