Ferodo Brake Pads
62 replies to this topic
#21 gaffer1986
gaffer1986
  • 4,408 posts
Posted 19 October 2015 - 12:25 PM
Just looking at the specs for the DS2500 - they don't appear to be any better than the Mintex 1155 pads I already have.
I was looking at the Pagids - again the RS42 (blues) also don't appear to be better - have I got this right?
I understand that M1155 don't work well from cold so should not be used on the road. I don't know much about he pagid. Here is a link about the Mintex:
http://www.retro-uk....mintex_pads.htm
My friend uses Ferodo DS2500 on his S2000 and says they wear quickly but are good from cold with little fade on track, they still fade a bit though but maybe this is the best compromise whilst still suitable for the road.
#22 gaffer1986
gaffer1986
  • 4,408 posts
Posted 19 October 2015 - 12:26 PM
oh noes, don't say that, the OP will cry :lol: :lol:
He maybe will if he realises the DS2500 etc. are technically road illegal anyway on the stock calipers due to [color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]ECE R90 [/color]
Are they? That's something I'm ignorant about. I haven't bought any yet, thanks for letting me know.
#23 gaffer1986
gaffer1986
  • 4,408 posts
Posted 19 October 2015 - 12:34 PM
What about these?
http://www.seriously...andard-calipers
#24 PaulCP
PaulCP
  • 6,066 posts
Posted 19 October 2015 - 12:53 PM
Wrong colour😄😄😄
#25 Tibbles Stryker
Tibbles Stryker
  • 1,941 posts
Posted 19 October 2015 - 01:02 PM
Never had an issue stopping with 1155 on the road dude, not exceptional but adequate 👍
#26 Kieran McC
Kieran McC
  • 3,416 posts
Posted 19 October 2015 - 01:18 PM
My Performance Friction pads have lasted 12 months ,3 European trackdays and 10 in the uk not bad for 300 + £ s
#27 Mattyboi
Mattyboi
  • 482 posts
Posted 19 October 2015 - 01:31 PM
I have Pagid RS42's after killing a set of road bias mintex on a track day. I put in new RS42's front and rear plus fresh fluid and the brakes are amazing! They havent faded on track, even when really pushing on or doing extended sessions. They're good on the road from cold and mine dont squeal. I did replace all pins/anti squeal pads when they were fitted so that might help with the noise. With regard to performance when cold, its easy to think they arent very good when cold because the performance when warm is so good but in reality mine seem as good as standard pads when cold.
When I chose these i was put off the CL pads because of the de-laminating issue. When I fitted the Pagid my friend in an Elise S2 fitted some  Mintex 1144, we've done the car limits day, a few road trips and two bedford track days and his pads have 2mm left, mine are about 1/3rd worn plus offer better performance.
I havent used any other upgraded pads so cant comment on others but for me these are well worth the cash.
#28 gaffer1986
gaffer1986
  • 4,408 posts
Posted 19 October 2015 - 06:48 PM
Lot of different opinions when it comes to pads. Some people have squeal and others don't from the same pad, odd, maybe it's down to how you install them.
#29 gaffer1986
gaffer1986
  • 4,408 posts
Posted 19 October 2015 - 06:49 PM
Wrong colour😄😄😄
haha, I have a silver NA, colour is obviously not on my list of prioities  :D
#30 gaffer1986
gaffer1986
  • 4,408 posts
Posted 19 October 2015 - 06:59 PM
Reading about them they sound pretty good. What discs are you using?
#31 Baron Von Scubadaddy
  • 6,645 posts
Posted 19 October 2015 - 07:07 PM
Im using standard pagids i think
3 trackdays done now
still a bit of meat on the pads(runs outside to check)
I think changing the fluid is key to good brakes
#32 gaffer1986
gaffer1986
  • 4,408 posts
Posted 19 October 2015 - 07:10 PM
Agreed, good fluid is probably more important as wet fluid normally boils before brakes fade, but organic OEM brakes still get soft when hot. How many laps do you do before you let them cool down?
#33 gaffer1986
gaffer1986
  • 4,408 posts
Posted 19 October 2015 - 07:15 PM
Saying that, the Pagid RS42 are organic so probably more to it than that.
#34 Kieran McC
Kieran McC
  • 3,416 posts
Posted 19 October 2015 - 07:42 PM
Fluid use something like Motul 660 , Braided brake lines help.
#35 gaffer1986
gaffer1986
  • 4,408 posts
Posted 19 October 2015 - 08:14 PM
I have ATE blue at the moment and have been planning to change to Motul 660 when needed, I hear good things about it.
#36 Mattyboi
Mattyboi
  • 482 posts
Posted 20 October 2015 - 07:22 AM
I've got EBC grooved and drilled/dimpled. They came on the car and were nearly new so they stayed on, they are good and not to expensive, havent used standard discs so cant comment on how much of an improvement they are.
I know the pads I use are really expensive, the discs are more expensive than standard to, but I wouldnt change from either of them. The pads show no sign of fade on track (20-30 min sessions) which is the main reason I got them.
I was tempted to try some track spec mintex etc as they are half the price but if they turn out to be crap i'll be £120 down. Its not worth the risk now I've got a good set up. Same with CL's, i would like to try them as they seem as good as pagids but they are known for coming of the backing, I didnt deem it a risk worth taking.
#37 gaffer1986
gaffer1986
  • 4,408 posts
Posted 22 October 2015 - 09:11 PM
Apparently these will fit the VX220, seems like a cheap way to get Pagid RS4-2 pads?
http://www.hangar111...pads-front.html
http://www.hangar111...-pads-rear.html
#38 Dakkon
Dakkon
  • 186 posts
  • Interests:Cars, Motor Racing, Computers, Ski-ing
Posted 23 October 2015 - 10:05 AM
CarboTech pads for me, use on the road and multiple trackdays, really like them
#39 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 24 October 2015 - 10:03 AM
Pagid are a good choice - not the cheapest but they do the job.
I've been using the RS14's but they're another step towards track than the 42's. They work perfectly from cold, the dust isn't corrosive but they do rattle and squeal a bit. The pay off is that they will stand more track abuse.
#40 Raptor
Raptor
  • 942 posts
Posted 24 October 2015 - 10:11 AM
are you using the 14's in both the front and back?  If so any issues with bias?
