Those Who Track Their Vx
Posted 13 May 2016 - 08:45 AM
Posted 13 May 2016 - 08:54 AM
Safety items first.
Posted 13 May 2016 - 08:55 AM
As in cage, or bushes and brakes?Safety items first.
Edited by Chriscvx, 13 May 2016 - 08:55 AM.
Posted 13 May 2016 - 09:02 AM
What's your experience on track driving?
Posted 13 May 2016 - 09:10 AM
Decent uprated pads
Decent fresh brake fluid
New or better yet uprated rear toe links
Uprated replacement hub carrier bolts (rear especially)
Gearbox oil breather mod
Posted 13 May 2016 - 09:11 AM
Ive been using an E92 M3 for a while. And while using Cup 2 tyres, H&R roll bars, full stoptech ST60/ST40 brake upgrade. updated settngs to the dampers with eibach springs (wanted to retain the EDC function), DCT gearbox updated to GTS settings. Geo settings adapted to me. Sorry if this all sounds foreign, but had M3's for around ten years now. Silverstone is probably my favorite track (GP) then Donnington. Do Spa once a year, and the Ring twice a year when i can, although done Spa a couple of months back, and the Ring will be in July. Did Bedford last monday in a Radical SR1. I have an F82 M4 now, but dont want to track it. But i will do Spa and the Ring in it.What's your experience on track driving?
Posted 13 May 2016 - 09:20 AM
Decent uprated pads
abs cutt off switch.
Some toe links movies to show the importance:
Edited by smiley, 13 May 2016 - 09:26 AM.
Posted 13 May 2016 - 09:24 AM
Decent uprated pads Decent fresh brake fluid New or better yet uprated rear toe links Uprated replacement hub carrier bolts (rear especially) Gearbox oil breather mod
Excellent! ABS cuttoff though?abs cutt off switch.Decent uprated pads Decent fresh brake fluid New or better yet uprated rear toe links Uprated replacement hub carrier bolts (rear especially) Gearbox oil breather mod
Posted 13 May 2016 - 09:25 AM
Edited by Chriscvx, 13 May 2016 - 09:25 AM.
Posted 13 May 2016 - 09:30 AM
Ah right so you've done a bit then
Seems you like the fast power circuits so you may find the NA a little frustrating. Driving at Silverstone GP convinced me that supercharging my car was the way to go. All the above upgrades/checks are the places to start anyway.
Posted 13 May 2016 - 09:32 AM
Posted 13 May 2016 - 09:34 AM
Its more those cicuits as the M3 was suited, especially Silverstone. Cadwell or Croft would be great, but im just after the experience now, and not chasing times. Love track days, and want to do around one a month, or maybe two. Just the cost in the M3/M4 is crazy.Ah right so you've done a bit then
Posted 13 May 2016 - 09:36 AM
think most people use mintex 1155 for track, cant comment.
def cut the abs, that made a world of difference to me.
Posted 13 May 2016 - 09:41 AM
Pagid RS14/4-2 are fine, DS2500 also, they are slightly more road/track biased.
If you want something more track focused and don't care about what they do to your wheels look at the Performance Friction pads. PF01's etc.
I won't comment on the CL's
Edited by rob999, 13 May 2016 - 09:42 AM.
Posted 13 May 2016 - 09:42 AM
my brake pedal used to go really hard and provide no stopping power..... think its called ICE mode or something.
sady cant just pull the fuse as I think that kills the stack.
Posted 13 May 2016 - 09:44 AM
You won't enjoy the ice mode of the 2 channel ABS, most fit the cut off switch, others have gone for the 4 channel exige unit which pretty much eliminates it.
Edited by rob999, 13 May 2016 - 09:44 AM.
Ah ok, umm no brakes sounds like fun! Whats the easiest way to disable the ABS then?my brake pedal used to go really hard and provide no stopping power..... think its called ICE mode or something. sady cant just pull the fuse as I think that kills the stack.
Posted 13 May 2016 - 09:50 AM
If you can access it, unplug one of the abs sensor plugs around the suspension (any accept rear left) to trigger the disablement of the abs.
As it's in a shite location to access, people just put in a switch on that abs wire for convenience. That's called the "abs cut off switch".
You could just give it a go without. If on track you are getting ice mode, you can unplug it anyway.
Make sure to tyrib it against the suspension after unplug, or it could get schredded by the wheel.
Edited by smiley, 13 May 2016 - 09:57 AM.
