Powertrain. Camshaft Position Sensor On A Na.
na camshaft position sensor
16 replies to this topic
#1 Stocky
Stocky
  • 35 posts
Posted 08 July 2016 - 02:27 PM
Hi,
Ive had this error pop up (in pic)
Attached File  Screenshot_2016-07-08-15-10-58-1-1.png   106.19KB   12 downloads
Have had a good look around the forum about where the Sensor is, but cant find a picture or diagram anywhere. Could someone please point me in the right direction.
Cheers :D
#2 siztenboots
Posted 08 July 2016 - 02:38 PM
2.2 engine does not have one, the 4 stroke phase is determined by crank sensor and ion sensing by the coil pack more details here ; http://www.speedster...entatie/csi.pdf
#3 techieboy
Posted 08 July 2016 - 04:18 PM
Fuggered coil pack, most likely.
#4 smiley
smiley
    Thetan level 15
  • 10,427 posts
Posted 08 July 2016 - 04:48 PM
I had that code when my tmap got disconnected.
So maybe could be temp sensor in inlet pipe?
#5 DaveyC
DaveyC
  • 259 posts
Posted 08 July 2016 - 05:00 PM
If it is the coil pack, I have spare and live in just over the boarder in Warwickshire. You're welcome to try it.
#6 Chris P Duck
Chris P Duck
    I can change this?
  • 1,506 posts
Posted 08 July 2016 - 05:13 PM
I had this after I got caught in a downpour, dried coil pack, spark plugs wells and all the electrical contact bits inside the rubber spark plug boots (3 parts in each boot, push out easy with a screwdriver) and all good. Zero expense.
Edited by Chris P Duck, 08 July 2016 - 05:15 PM.
#7 smiley
smiley
    Thetan level 15
  • 10,427 posts
Posted 08 July 2016 - 05:34 PM
If you find the cause, let us know, so we can update the codelist.
#8 Stocky
Stocky
  • 35 posts
Posted 08 July 2016 - 06:39 PM
Ok, I have the original coil pack. I took it off as I had bad starting problems and it cut out when hot. The new ebay coil seems to be throwing up this code so will go and swap back and re test. Will update you in 10 minutes.
#9 techieboy
Posted 08 July 2016 - 06:42 PM
Have you got a cheapo replica coil pack? They've certainly been known to cause the error.
#10 smiley
smiley
    Thetan level 15
  • 10,427 posts
Posted 08 July 2016 - 06:49 PM
What the techmeister says.
Chinese knockoff coilpacks have poor ion sensing. (usually throws P0340 in that case)
#11 Stocky
Stocky
  • 35 posts
Posted 08 July 2016 - 07:00 PM
Yes, ninety spondoolies.
#12 Stocky
Stocky
  • 35 posts
Posted 08 July 2016 - 07:02 PM
OK, OEM coil back on and have reset faults on ecu. Will take it for a run and see if shes faultless. Still poor starting though.
#13 Stocky
Stocky
  • 35 posts
Posted 08 July 2016 - 11:36 PM
Have run it all night and no faults. Rough running and poor starting are back . Also got done by a lotus Elise on the ring road. :(
#14 smiley
smiley
    Thetan level 15
  • 10,427 posts
Posted 09 July 2016 - 12:03 AM
Get a used coilpack. Maybe also check plugs.
#15 Dan r
Dan r
  • 666 posts
Posted 10 July 2016 - 11:58 AM
Crank position sensor is an arse to change, but I managed to get hold of a second hand one delivered for £7 from eBay, so a cheap fix if its that. If you can't find one I have a spare.
#16 Stocky
Stocky
  • 35 posts
Posted 15 July 2016 - 12:56 PM
Hi Dan, yeah I think it's the sensor. :( Would be great to buy your spare if you still have it by any chance? Mike. Sent from my SM-G900F using Tapatalk
#17 Dan r
Dan r
  • 666 posts
Posted 15 July 2016 - 05:20 PM
You have pm
Also tagged with one or more of these keywords: na, camshaft position sensor
