Opcom On Windows 7 - Why Won't It Work?
#21
Posted 29 October 2016 - 06:37 PM
#22
Posted 14 November 2016 - 10:03 AM
I bought another OPCOM in the end from a different seller. Haven't had time to try it on the car yet, but this one allows me to run the self diagnos test in OPCOM properly so I assume it will work.
To get into the ABS on the VX - do you have to select Astra? or can you access it by selecting the VX? I had in mind I read that the airbag for example requires to select Astra as model?
#23
Posted 14 November 2016 - 01:30 PM
I thought the ABS was Lotus specific
#24
Posted 14 November 2016 - 02:49 PM
Only if you (retro)fit an Exige/Elise ABS controller. Then you need to use a Lotus scan-tool to access the ABS unit.
The original 2-channel VX ABS controller can be interrogated and checked with regular Vauxhall/Opel scan-tools just like the ECU and Airbag units.
