Ok so i haven't done a power run but its a number i i no its fast lol i don't need a number to tell me that lol
How fast will it go mister?!
Posted 17 April 2017 - 05:40 AM
Posted 17 April 2017 - 07:28 AM
You worried nev of being knocked off quickest vx220 slot ;-pHow fast will it go mister?!Ok so i haven't done a power run but its a number i i no its fast lol i don't need a number to tell me that lol
Posted 17 April 2017 - 11:41 AM
I'd be really happy for Lee if his is faster, mine is plenty fast enough for me.
I simply enjoy seeing people experimenting and coming up with different/improved solutions. I follow this very interesting group on facebook, every day I see stuff on it that impresses me with people's (often amateurs) inginuity.
We are lucky (or perhaps well informed) to all have one of the best mid engined base cars to experiment with.
Edited by Nev, 17 April 2017 - 11:46 AM.
Posted 17 April 2017 - 02:32 PM
I'll do that with mineYou worried nev of being knocked off quickest vx220 slot ;-pHow fast will it go mister?!Ok so i haven't done a power run but its a number i i no its fast lol i don't need a number to tell me that lol
Posted 17 April 2017 - 02:55 PM
Alex was updating me about your build, sounds super impressive. I'm not sure I'd want to be a passenger in it as I get scared easily.
You can drag it out against Lees car, that would be interesting, 600 supercharged HP vs 600 turbocharged HP. I understand he has a private testing road
I hope you boys make some checks about your bodywork rigidity, it's a serious issue with the power you are making. My own front clam flexs at high speed and causes the undertray to flex and breaks the fixing points. Worth reviewing IMO.
Edited by Nev, 17 April 2017 - 03:01 PM.
Posted 12 May 2017 - 11:52 AM
Edited by CHILL Gone DUTCH, 12 May 2017 - 11:52 AM.
Posted 12 May 2017 - 12:40 PM
What's torque is it making then? 400 ft/lb ?
Posted 12 May 2017 - 01:43 PM
Its a lot more torque than my 2.2 1320 harrop which is 416NM which is around 305 ft lb
i dont want to put a estimate on it nev but if your asking me to guess maybe not 400 ft lb but significantly more than mine
Posted 12 May 2017 - 02:37 PM
How much boost is it making @ idle?
That long throw crank should make some nice torque numbers with the 1900 TVS. Poor gearbox and axles...
Posted 12 May 2017 - 02:38 PM
you mean poor me sat in the passenger seat
trying to get lee to go part throttle is like asking a nun for a blow job
Posted 12 May 2017 - 02:42 PM
when it was on the bigger pulley idle was about 65 kpa and around 190-200 kpa at high rpms
lee has a smaller drive pulley
he now has reduced the charger pulley size and its running around 250 kpa at high rpm
i will let you know the current idle kpa on the smaller pulley when lee emails the latest files
Edited by CHILL Gone DUTCH, 12 May 2017 - 02:43 PM.
Posted 12 May 2017 - 03:52 PM
Was more joking that this thing will make boost pressure from idle rpm on...
Posted 12 May 2017 - 07:35 PM
There are stiff but camber is necessary. My front Zzr a24 where is -2 degrees camber after one trackday looks http://www.mazdaspee...33717&mode=viewYeah ZZRs need less camber than most R-rated tyres because the tyre walls are so stiff that the carcuss of the tyre moves around less. Anything over 3.5 is pretty extreme IMO
No but the zzr's are much better Need to ad some shims
Ahh okayThey where super softs but yes 1 track day
Do they wear evenly?
Edited by piwo, 12 May 2017 - 07:36 PM.
Posted 12 May 2017 - 08:00 PM
Posted 14 May 2017 - 06:03 PM
Ooof !
Posted 18 May 2017 - 04:49 PM
Edited by leevx2.2, 18 May 2017 - 04:50 PM.
Posted 18 May 2017 - 05:11 PM
Sweet!!!!
Posted 18 May 2017 - 06:48 PM
Posted 18 May 2017 - 06:57 PM
Nice. That's the most extreme approach to noise reduction yet
yes but if it works its worth it might even be able to do bedford
if i had the room i was thinking about fitting a valve so i could use one box or two
Edited by leevx2.2, 18 May 2017 - 06:59 PM.
