Basic Or Full Geo
25 replies to this topic
#21 chris_uk
Posted 18 January 2017 - 09:51 PM
Cheers guys for the input, but I don't suppose anyone has gone from a basic geo done at a specialist to a full Geo and noticed a great deal of difference?
Depends what you mean by "full" geo. If this just means caster then the difference will be minimal. You can do this yourself as it's normal just to max it out (2 washers either side is normal, 3 rear one front is maxed out if you're using standard bushes) If "full" geo involves corner weighting, bump / rebound setting etc etc the difference will be more pronounced.
exactly, the real question is would you "need" a full geo based on what you are going to use it for.
#22 Nev
Posted 18 January 2017 - 11:44 PM
I'm not convinced increasing the castor is a good idea personally, it can dull the steering feel as the wheels want to self-align too much.
Some of the best handling cars (like Alfas in the 70s and 80s) had almost no camber for instance.
Edited by Nev, 18 January 2017 - 11:45 PM.
#23 chris_uk
Posted 19 January 2017 - 06:41 AM
Static or on bump?
#24 siztenboots
Posted 19 January 2017 - 07:43 AM
Mixing up caster and camber
#25 Nev
Posted 19 January 2017 - 08:02 AM
Ooops, yes I meant caster in the second sentence of posting #22, sorry.
Edited by Nev, 19 January 2017 - 08:03 AM.
#26 Nev
Posted 19 January 2017 - 10:11 AM
Another thing is that switching to semi-slick tyres (sometimes with lower profiles) means that the side walls may flex and bend far less. This is partly due to less sidewall height, stronger carcass, more plies etc etc. As a result when cornering (in theory) you need less camber, as the tyre is far more rigid. In practice though if you get them really hot then the increased friction may allow you to pull more G, thus meaning you need extra camber. Anyway my point is the change of tyre and way your drive can greatly influence the way your should set the car up.
Edited by Nev, 19 January 2017 - 10:22 AM.
