Pressure at the fuel rail tells you the pump is working, therefore cut off is not activated. It doesn't tell you if the injectors are being instructed to inject
Non Starter Again - Help Please
#21
Posted 23 January 2017 - 03:35 PM
#22
Posted 23 January 2017 - 06:24 PM
why not just replace the damaged fuse if its melted?
The fuse is probably not related to the non starting as its in the front and it's te headlamp one.
And why can't I replace it? - it's melted so bad it's welded itself into the fuse holder!!! Snapped trying to dig it out so the pins are now stuck down in the holes. Will have to extract the fuse holder and attack from underneath. Anyway - with Matt now.
#23
Yes....that had crossed my mind.
#24
Posted 23 January 2017 - 06:44 PM
#25
Posted 24 January 2017 - 06:39 PM
Dead ECU. Possibly caused by the electrical problems up front with the melted fuse? Or corroded contacts on the ECU itself - quite poor condition apparently.
So, 2nd hand VX ECU, new VX ECU, new Courtenay map, MBR map, standalone ECU with MBR map - decisions, decisions!
#26
Posted 24 January 2017 - 07:39 PM
#27
Posted 08 February 2017 - 06:16 PM
So, to wrap this up. 2nd hand VX ECU fitted and equipped with MBR/TeamVX (sizeten) map.
Feels great - more power/torque than before (north of 300) and more importantly vastly improved delivery. Loving it! (not the cost though )
