So they are in stock? @ Opel , like Akra said, they're gone
Turbo Side Engine Mounts
#21
Posted 09 May 2017 - 01:45 PM
#22
Posted 09 May 2017 - 04:41 PM
#23
Posted 09 May 2017 - 06:35 PM
Apparently so - parcel arriving tomorrow.So they are in stock? @ Opel , like Akra said, they're gone
#24
Posted 10 May 2017 - 11:46 AM
#25
Posted 10 May 2017 - 01:15 PM
They've arrived, just measured & excluding the two locating lugs they're 69mm, so appear to be correct (measured in a vice). Will compare with the ones I remove, but so far so good.
#26
Posted 10 May 2017 - 04:13 PM
By vx standards it's an ok job. Just need a long extension for the side mounts.Yep - ordered from Elise parts last night along with the inserts for the front & rear. Thanks all for the input - some scrabbling around on the floor coming up...
#27
Posted 10 May 2017 - 07:20 PM
#28
Posted 13 May 2017 - 04:23 PM
Well that was a fun couple of hours... I have the wrong size hands for a VX220. The pic below is the passenger side mount, surprised it wasn't making a worse noise given it had completely come apart. Having taken it out since the difference is quite noticeable - as others have said everything feels a lot more together under hard acceleration.
The mounts were a good fit - I don't believe they're Vauxhall ones - the ones I took off had GM markings on them, the new ones don't.
I did a bit of reading first (absolutely tape your sockets to the extension bars!) & would advise tackling the passenger side first - it's more accessible & you can see more of what you're doing, the drivers side is the same but you cant see it so having done the other side helps. Definitely remove the top intercooler hose, makes life easier.
Rob
#29
Posted 23 May 2017 - 06:04 PM
Mine have just gone and got track day to go to this weekend! New ones arrived today but got no one to fit them as yet.
#30
Posted 23 May 2017 - 06:07 PM
#31
Posted 23 May 2017 - 07:26 PM
I wouldn't attempt on my own, don't have the tools for a start. Based 10 miles north of Brighton. Will try ringing round tomorrow but the problem is I'm going to Edinburgh for work the next 2 days.
