1.7 Bar?
#41
Posted 05 December 2017 - 10:59 AM
#42
Posted 05 December 2017 - 12:51 PM
#43
Posted 06 December 2017 - 06:44 PM
Edited by james4563, 06 December 2017 - 06:44 PM.
#44
Posted 20 December 2017 - 10:49 PM
#45
Posted 21 December 2017 - 07:10 AM
1.5bar at 2500rpm which makes it even stranger why Courtney would tell me that's not possible. They did map it after all. Going to call them tomorrow and discuss.
Yep, the OEM MAP sensor sends a 0 to 5 volt signal based on 0 to 1.5 Bar of boost, so your info concurs with the sensor's range.
What "stage" is your car meant to be mapped to and what mods does it have (eg does it have a CC?).
Edited by Nev, 21 December 2017 - 07:20 AM.
#46
Posted 21 December 2017 - 06:13 PM
#47
Posted 22 December 2017 - 12:56 AM
Sounds fishy to me, if it's making that much boost so early in the RPM range probably means the engine can't consume the charge for some strange reason...
If the OEM could get the turbo to spool completely by 2400 RPM then they'd do it (as it would lead to better economy (ie the onset of earlier torque)), so if they can't I find it hard to understand how your car is managing it.
Edited by Nev, 22 December 2017 - 01:11 AM.
#48
Posted 18 February 2018 - 04:02 PM
I can't remember if I posted this before but here are some of my dyno graphs.
https://drive.google...2k4VF8xZm1rNF9B
https://drive.google...TZSZ1M1M2VkV0o4
Peak overboost at ~2400rpm. Compared to the graph a few pages back which makes peak boost at like 3.5k RPM. Courtney said to me it depends of course on when you put your foot down, but the graph on the previous page runs from even lower RPM than mine does anyway.
After all the stuff I've now replaced I guess it must be the map. Regal did a bit of diagnostics and said that the ECU is asking for maximum boost (255?) as soon as you put your foot down, which I guess suggests that it is the map. It's only got a 2.5bar MAP sensor as well, which means that the ECU can only fuel for 1.5bar off boost. So seems a bit strange why it would be mapped to allow such high overboost.
I have emailed siztenboots regrading a remap to see if that changes anything.
I've not seen any CS stage 4 dynos that look like mine does. Even from the astra forums.
#49
Posted 18 February 2018 - 04:11 PM
You could consider binning the OEM ECU and buying a 3rd party one and get it mapped - would give you far smoother delivery and the ability to tweak the map yourself to suit conditions. would cost a bit though.
#50
Posted 19 February 2018 - 01:30 PM
email replied to
#51
Posted 19 February 2018 - 02:15 PM
not sure if it was you calling , but just cut you off getting the phone out my pocket
/edit , no sorry it was another customer , lol
#52
Posted 27 February 2018 - 01:22 PM
#53
Posted 27 February 2018 - 05:06 PM
1. Have you put a camera in the engine bay, focused it on the wastegate/actuator yet and taken it for a drive, so you can see if the wastegate is opening in the video?
2. Have you tried manually moving the actuator (by hand) to see if it is free to move?
Edited by Nev, 27 February 2018 - 05:08 PM.
