Outer Toe Link Fitted Incorrectly ?
46 replies to this topic
#1 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 04 December 2017 - 12:59 PM
Hi all
On behalf of Acidpopstar (Neil) and myself could i pick your brains.
Whilst putting Neils car back together I came across an anomaly between left and right rear toe link outer joint fittings.
Attached File  IMG-20171203-WA0006.jpg   134.32KB   6 downloadsAttached File  IMG-20171203-WA0001.jpg   123.26KB   6 downloadsAttached File  20171204_114646.jpg   189.87KB   6 downloads
From left to right:    left rear link , Right rear and third image shows the standard joint spacer from oem.
Problem is that the left rear has the oem spacer in along with the new toe link fittings and the right rear doesn't so which should it be ?
Neil has had a caliper thread repaired in the past on the right rear (wrong bolt now in there but thats another story) so has it been left out, furthermore as the spacer is smaller in diameter than the toe link kit then I would think that it is adding more shear to the bolt than I would expect.
Can anyone identify the kit type - personally I think its an EP one.
John
#2 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 04 December 2017 - 01:02 PM
Attached File  IMG-20171203-WA0003 (1).jpg   26.13KB   6 downloadson and one more
#3 Arno
Arno
  • 1,233 posts
Posted 04 December 2017 - 01:17 PM
Both look wrong.
For the N/A upright straight bore toe link connection (M10) you need this spacer/adapter to fit in the upright cavity:
The later turbo upright (and toyota elises) have a tapered bore M12 connection and use this adapter:
Looks like whoever fitted this toe-link originally made an odd mashup of the OEM toelink bits and the eliseparts toe link bits but didn't use all the correct parts.
#4 Acidpopstar
Acidpopstar
  • 3,555 posts
Posted 04 December 2017 - 03:31 PM
Thanks Arno! Sent from my iPhone using Tapatalk
#5 CHILL Gone DUTCH
Posted 04 December 2017 - 04:13 PM
have you had the hub carriers changed at some some point
#6 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 04 December 2017 - 11:10 PM
Agree Arno, not a quality job at all. Chill, Neil tells me that he had a caliper bolt drilled out on that same side. We suspect that was when it was put back together with the spacer, though wrong missing. Neil has said that it struggles to turn in well in one direction. Sent from my SM-G903F using Tapatalk
Edited by Johnboyhgt, 04 December 2017 - 11:12 PM.
#7 vocky
Posted 05 December 2017 - 07:53 AM
I would advise you make both sides the same (you could use a pair of OEM spacers, one per side), but I would not recommend using flat washers as the spacer
#8 siztenboots
  • 26,610 posts
Posted 05 December 2017 - 08:19 AM
Will have a look to see if I have the spare NA spacers from my Elise-shop kit , as you get both types of fittings from them
#9 Nev
Posted 05 December 2017 - 08:51 AM
Good job you noticed this JohnBoy. It's quite startling what some previous fuknugget has done. :(
Edited by Nev, 05 December 2017 - 08:56 AM.
#10 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 05 December 2017 - 09:06 AM
Agree Nev
Probably a good job that Acidpopstar only managed one lap of Spa before his breakdown.
#11 siztenboots
  • 26,610 posts
Posted 05 December 2017 - 09:11 AM
presumably these are the same parts fitted during his french frolic trip last year including the mountain driving afterwards
#12 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 05 December 2017 - 09:20 AM
Very kind of you to look Siztenboots
#13 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 05 December 2017 - 09:48 AM
i would assume so !!
#14 Spitfire Engineering
  • 754 posts
Posted 05 December 2017 - 10:36 AM
Hi all
Posted ImageIMG-20171203-WA0006.jpgPosted ImageIMG-20171203-WA0001.jpgPosted Image20171204_114646.jpg
John
Looks like Stainless rods so that would suggest Elise Shop though it could be the coating on the EP ones, hard to tell.
Any idea how long this has been fitted?
Looks to me like someone ordered/fitted the wrong kit and has tried to bodge the tapered fittings onto a recessed upright.
You could try contacting the dealer for support?
One thing for sure it's dangerous as it is now.
Edited by Spitfire Engineering, 05 December 2017 - 10:38 AM.
#15 Spitfire Engineering
  • 754 posts
Posted 05 December 2017 - 10:40 AM
Hi all
John
On the image with the toe link coming in from the right, what is stopping the collet going further into the recess?
#16 Spitfire Engineering
  • 754 posts
Posted 05 December 2017 - 10:47 AM
OK, forget the last question above ...
Unbelievable.
I'm surprised he even got to the track.
I really hope this was not fitted by any of the dealers.
Were there no instructions for fitting the kit?
#17 Spitfire Engineering
  • 754 posts
Posted 05 December 2017 - 11:06 AM
Personally I would not try to patch it up, for a start you will not know the reference height for the bump steer and it would need multiple spacers anyway, bad enough the collet does not secure the ball joint into the recess with a snug fit as a single component. Separate components are not ideal with the M10 and multiple separate components is asking for trouble as each section can slide allowing further bolt travel as the shear forces increase.
Easier and safer to start again in this case, strip the bearings and examine all the collets to make sure they have not deformed.
Get back to the manufacturer and order the correct parts with new bolts etc
Can we get a picture of the nut please in full height?
Ta
Gaz
#18 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 05 December 2017 - 11:12 AM
nut in full height ??
John
#19 Spitfire Engineering
  • 754 posts
Posted 05 December 2017 - 11:17 AM
John
Please.
Directly from the side, in the pic it is shadowed by the upright.
Or you measure with callipers if it is off the car now?
Edited by Spitfire Engineering, 05 December 2017 - 11:18 AM.
#20 Johnboyhgt
Johnboyhgt
  • 1,311 posts
Posted 05 December 2017 - 11:34 AM
Have another pic from the side will post shortly.
