2,2Na Engine Build 200Hp Idea?
38 replies to this topic
#21 Jocke_D
Jocke_D
  • 407 posts
Posted 09 January 2018 - 02:56 PM
There are lots (at least some) that do the yearly tripp to "bilprovningen" with chargers on. I have done it myself two times and not a word about the charger. The last time the guy even asked to see the engine because he was interested. His conslusion was "cool".
I think the trick is that our cars are really unusual for the people there to see. They might know that Lotus often use engines from other brands and if they really know their stuff they might even know of a charged Lotus. If you try to make the installation as OEM looking as possible I can't se why it should be a problem.  Since the charger is OEM (from another GM car) it really looks OEM.
The dutch software gives you the oportunity to "de tune" your car once a year if you want to.
ITB's will be more easy to spot, I think.
#22 Rosssco
Rosssco
  • 4,185 posts
Posted 09 January 2018 - 03:44 PM
Generally, does anyone know if there is a (ahem) MoT calibration that would assist those who have a thing that looks like a cat, but contains not cat.. Or does it not work like that..
#23 Mikael.Swe
Mikael.Swe
  • 11 posts
Posted 09 January 2018 - 08:44 PM
It is just a case of swapping a few wires around in the plug. I assume you will have a TB loom extension if running the Dbilas currently? Well remembered Smiley
I got an extension to TB loom, it's about 20cm long. I have not installed intaket yet
#24 Mikael.Swe
Mikael.Swe
  • 11 posts
Posted 09 January 2018 - 08:47 PM
Thank you for all the great advice and tips! 👍
#25 Mat Jackson
Mat Jackson
  • 1,579 posts
Posted 12 January 2018 - 03:04 PM
I have a similar aim for mine. Currently have itbs fitted, piper cans and 4-1 manifold with vse backbox. Plan for later this year is port and skim the head (Vocky), diblas springs, and add a 2.5” Tullett down pipe and cat, but keep the VSE backbox. Hoping for close to 200bhp... Was considering stage 2 cams to, but the power is pretty similar upto 7000rpm, so not sure it’s worth it for road use. Sent from my iPhone using Tapatalk
#26 Paulus H
Paulus H
  • 2,063 posts
Posted 21 January 2018 - 03:26 PM
I would have said the biggest benefit of these types of mods is that the car will have a more rev hungry character as befitting this kind of car.
Paul
#27 slindborg
Posted 21 January 2018 - 03:45 PM
Sadly it's very very hard, if not impossible to pass a cat test without a cat, as the cat does actually facilitate science.
#28 Vladimir
Vladimir
  • 111 posts
Posted 30 January 2018 - 03:27 PM
That’s what you’ll get by fitting Dbilas N/A inlet manifold, 68mm Throttle body, Dbilas race cams, Bosch 470cc injectors (0280156280), 2,5 exhaust with 200cell cat and Dutch ECU
You can decide whether it is worth the price.
180hp on the flywheel at 6200rpm
Edited by Vladimir, 30 January 2018 - 03:28 PM.
#29 oakmere
oakmere
  • 2,143 posts
Posted 05 February 2018 - 01:32 PM
On the N/A engine you have to improve all parts of the intake head and exhaust to get the most out of it. The above figures look correct if not using a high flow exhaust manifold and a ported head. You will get better power and much more torque with the 2.4 inlet manifold though!
#30 2-20
2-20
  • 1,317 posts
Posted 06 March 2018 - 10:21 AM
Thats what youll get by fitting Dbilas N/A inlet manifold, 68mm Throttle body, Dbilas race cams, Bosch 470cc injectors (0280156280), 2,5 exhaust with 200cell cat and Dutch ECU
Vladimir , your curves show that your torque is not yet decreasing and you power curve is still climbing....
So why did you stop it at this rev. Limit ??? There is a lot more power in your engine.
#31 WazzaVX220
WazzaVX220
  • 306 posts
  • Interests:Great Music, Love, Friends, Holidays, Great Wine, Cars, Beautiful places to drive Cars!!!
Posted 19 March 2018 - 05:09 PM
What sort of Torque does the Z22 Make when you Spec it up to 200bhp (with the 2.4 inlet etc)?
Would Love to see the Dyno Power Curve of yours (S-express)
Thanks!
#32 TheHood
TheHood
  • 1,036 posts
Posted 19 March 2018 - 07:48 PM
About 220Nm @ about 5kRPM (Sorry no plot, PTA to upload images these days 😕)
#33 piwo
piwo
  • 182 posts
Posted 20 March 2018 - 09:27 AM
my engine sports camshaft intake manifold 2.4 exhaust manifold 4-2-1 no balance shafts no chain and mechanical water pump (EWP) adjustable shaft wheels smaller 100A alternator lighter flywheel 68mm throttle body from cobalt ss
cat magnaflow
itg sponge air filter
stand alone ecu
http://www.mx5klubpo...e.php?id=44920
and about 14s on 1/4 mile (14,7 stock)
Edited by piwo, 20 March 2018 - 09:35 AM.
#34 2-20
2-20
  • 1,317 posts
Posted 20 March 2018 - 07:47 PM
What unit is KM on your graph??
#35 Mat Jackson
Mat Jackson
  • 1,579 posts
Posted 20 March 2018 - 10:31 PM
Km is same as bhp... Sent from my iPhone using Tapatalk
#36 colimbo
colimbo
  • 6 posts
Posted 21 March 2018 - 08:45 AM
68mm throttle body with standar ecu? Is it possible??? Enviado desde mi PRA-LX1 mediante Tapatalk
#37 vocky
Posted 21 March 2018 - 08:49 AM
I used to use the 68mm TB on my modified z22se and also the OBD ecu software now supports it
#38 adamvx220
adamvx220
  • 598 posts
Posted 31 March 2018 - 07:48 AM
sorry to highjack the thread but I have a 2.2 'stage3' 182bhp amd tuned car it has the following stage 3 cams (no.idea of the make) port n polished head full exhaust system lightened flywheel and a remap not sure if anything else was done as I brought the car like this? I do have a 2.4 mani to fit would i see much improvement would be nice to get it as close to 200bhp as poss all though hoping to build an sc engine this winter n probably sell this engine on as it's only done 42k ad
#39 TheHood
TheHood
  • 1,036 posts
Posted 31 March 2018 - 07:07 PM
On a similar spec I think I gained about 10BHP with a 2.4 manifold.
