Can the forum member who was kind enough to let me have an old shim a while back please remind me who he was.
I have a present for you
It was just one person before you all start!
Posted 13 February 2018 - 03:28 PM
Posted 13 February 2018 - 06:27 PM
Do you have a Picture of the gift for him? :-)
Posted 13 February 2018 - 06:45 PM
Posted 13 February 2018 - 07:46 PM
Was it Elmo?
Posted 13 February 2018 - 07:50 PM
I will on Thursday when I recover them from the finishers. S355 steel and finished with a zinc epoxy resin (93% zinc solids).
Significantly harder than OE (if and when they are available) and far, far better protected.
Oh, and cheaper.
Around £15 each or £28 a pair.
Posted 13 February 2018 - 07:53 PM
Was it Elmo?
Not sure, I guess I will have to trawl through Messenger .....
Considering the average names on here it's probably Thwassybollockboy or crazybluewongaperv etc
Posted 13 February 2018 - 09:34 PM
Could have done with these a few weeks back!!
Oh, and it wasnt me...
Posted 13 February 2018 - 10:54 PM
Are they available again then from Lotus?
Posted 13 February 2018 - 11:37 PM
Posted 14 February 2018 - 08:55 PM
Didnt get new ones. Mine werent too bad to be fair. Just slathered them in Duralac and refitted...
Posted 14 February 2018 - 09:33 PM
Gutted! These come available AFTER I've had the subframe off replacing mine.I will on Thursday when I recover them from the finishers. S355 steel and finished with a zinc epoxy resin (93% zinc solids). Significantly harder than OE (if and when they are available) and far, far better protected. Oh, and cheaper. Around £15 each or £28 a pair.Do you have a Picture of the gift for him? :-)
Posted 14 February 2018 - 10:42 PM
Not a job I want to repeat.
ditto. 9 months too late for me
Posted 15 February 2018 - 09:14 AM
Posted 15 February 2018 - 03:19 PM
Made from 2mm (OE 1.2mm) S355 for maximum deformation resistance.
They have been blasted just prior to spray coating with a 93% solid Zinc epoxy and slow baked to fully set.
This is about as good as it can get, there is no harder steel available in this thickness and the protection is the best available.
The only bad news is these should really be utilised before the chassis corrodes, not as a repair.
Chris is sending some nice corroded chassis pics later along with some info on how to check.
If you think the shim plate is bad in these pics you should see the chassis!
IMG_7793.JPG 131.29KB
19 downloads
IMG_7794.JPG 116.56KB
17 downloads
Not easy to picture the deformation caused by the expansion of the corroded metals.
IMG_7795.JPG 116.44KB
16 downloads
Edited by Spitfire Engineering, 15 February 2018 - 03:25 PM.
Posted 15 February 2018 - 03:32 PM
Posted 15 February 2018 - 08:26 PM
In case you ever want stronger (approx 3x) and consequently harder steel in 2.0 mmThis is about as good as it can get, there is no harder steel available in this thickness and the protection is the best available.
Posted 16 February 2018 - 01:10 AM
https://www.ssab.com...ical_properties
Quite correct, I should have qualified my statement
There is no stronger steel which is readily commercially available at a cost which is reasonable considering the application.
As good as it gets does not allow for £50 per shim
And this is before the brittleness of such a product is investigated......
Posted 16 February 2018 - 11:44 AM
http://www.vx220.org...rame/?p=1920267
That original thread should point you in the right direction and also maybe give you the sender's details (Garyk220?)
Posted 16 February 2018 - 11:24 PM
Yes I found it thanks though he has not been online here since last year
Posted 17 February 2018 - 10:57 PM
