Garw Screen Incorrect Values
Posted 16 April 2018 - 05:58 AM
Posted 16 April 2018 - 06:44 AM
thats in programming mode, push the joystick about and you can exit it
Posted 16 April 2018 - 07:19 AM
As Vocky said, thats the set up screen. If you exit to the main screen it should all read correctly.
Posted 16 April 2018 - 08:15 AM
Unfortunately, the same values in the setup screen shows on the live screen (the fuel % seems to be way off on the phone app) and water temp, boost and so on seem to not work as well.
Posted 16 April 2018 - 11:51 AM
See oil temp, pressure and fuel is at -63...
https://cloud.larsso...gtwDWGZ6Rt7ZoJN
Water temp is at 93 (set to C) but the engine had not been running in 3 months so i highly doubt the accuracy
Posted 17 April 2018 - 07:01 AM
I'm away from my car at the moment but I can take a look on Sunday at what mine is set at.
The oil temp and pressure wont work, you'll need additional sensors for that. My water temp reads high sometimes until I turn the engine on when it then reads correctly, it only does this before the first start up. My fuel percent is accurate.
Posted 17 April 2018 - 11:04 AM
I'm running with a ODB2 reader right now because i just installed a chargecooler so i'm unsure if my attempts at removing bubbles from the cooling system have been successful. Good to know about the oil temp/pressure but i guess fuel% and water temp would still be good to have.
By they way, anyone got a link to sensors that i could install to get the oil temp/pressure as well as anything else that might be interesting?
Is the intake temperature the air before or after the turbo?
Edited by VincentL, 17 April 2018 - 11:04 AM.
Posted 17 April 2018 - 01:25 PM
Posted 17 April 2018 - 06:28 PM
1. Upgrade the dash (unfortunately there is no update for the ic8)
2. Select an exige map and save, then select vx map and save. This didn't resolve my fuel%/water temp issues unfortunately
