Do I Need A New Battery?
12 replies to this topic
#1 .Adam.
.Adam.
  • 405 posts
Posted 11 December 2018 - 08:32 AM
Battery in the VX didn't start it the other day, so have taken it out and charged it. I have been monitoring the resting voltage, and it's fallen from 12.7v to 12.5v in about a week. Should it be holding it's charge better? I don't want the faff of having to take it out again if it's duff!
#2 quimbles
quimbles
  • 760 posts
Posted 11 December 2018 - 09:04 AM
disclaimer................havnt tried this.....
leave battery out and connect it up with some jump leads, see if it starts easy.
my battery only lasts about 2 weeks before its dead.
#3 vocky
Posted 11 December 2018 - 10:25 AM
take the battery to Halfords and get a free battery test done thumbsup
#4 siztenboots
  • 26,610 posts
Posted 11 December 2018 - 10:53 AM
do NOT ever do this , battery is very important part of voltage protection
#5 quimbles
quimbles
  • 760 posts
Posted 11 December 2018 - 11:33 AM
good to know lol
#6 ciderbooze
ciderbooze
  • 1,216 posts
Posted 11 December 2018 - 11:45 AM
I think (hope) quimbles is suggesting that , to save you having to fit the battery in order to see if it’s ok you could rather leave it out of the car and use jump leads to extend to the car.
#7 quimbles
quimbles
  • 760 posts
Posted 11 December 2018 - 11:53 AM
yes that, use the leads as an extension.  sizten did you think i meant start the car with no battery?  or does using the leads remove the voltage protection?
#8 siztenboots
  • 26,610 posts
Posted 11 December 2018 - 12:12 PM
yes , bypassing the battery is the problem
as a precaution when connecting two batteries , you should have a resistive load in the system , so turn on lights , fans
#9 .Adam.
.Adam.
  • 405 posts
Posted 11 December 2018 - 11:51 PM
I'll have to take it to Halfords for a test, see what they say .
#10 Sutol
Sutol
    Well it's nearly a Lotus
  • 8,120 posts
Posted 12 December 2018 - 07:25 AM
I have my battery disconnected while being stored. When I reconnect after a few months the car starts as good as gold. How old is the battery?
#11 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,509 posts
    "Yes, I built it"
Posted 12 December 2018 - 07:50 AM
Do you set the alarm when it's stored ? Or maybe something else draining the battery, I know my old turbo backup battery used to do that before I disconnected it.
The NA I own now has no battery drain
#12 .Adam.
.Adam.
  • 405 posts
Posted 12 December 2018 - 06:28 PM
It hasn't been used loads recently, but the last time I used it was around 2 weeks ago, took it for a 45 run, purely to keep the battery topped up! I can normally leave a few weeks no problem, and I disconnect the battery when I lay it up over the winter.
Battery is just over 4 years old.
#13 siztenboots
  • 26,610 posts
Posted 17 December 2018 - 10:55 AM
you could check each fuse , how many amps is being drawn when turned off. It could be something like car tracker hidden away.
