Plastic Sh*tbox Non-Starter
43 replies to this topic
#1 Rosssco
Rosssco
  • 4,185 posts
Posted 12 December 2018 - 10:21 AM
So, car not starting (SC'r). I had the clam off for a exhaust change and some other tweaks (none electrical).
Car started fine before putting the clam back on. Issue started once the clam was back on (probably incidental).
My first test drive down the road, car started fine. On test drive, started to splutter and miss badly, then cut out. Restarted, drove a little further, broke down, then wouldn't start.
Things I've check / changed
- battery is about 2 month old. Voltage a consistent 12v on my multimeter. Taken out, charged overnight. No difference
- Pump is priming (checked pressure in line through fuel line valve)
- Borrowed good starter relay (yellow one). No difference
- Changed alternator and checked it wasn't shorting on manifold
- checked earth connection on chassis. Seems fine and was never removed disturbed
- Checked all fuses. Fine.
- pulled x2/x3 connectors to ensure they were clean. Look fine (never had an issue with them)
- Cleaned battery terminals
- Fitted a -neg battery terminal isolator thing. Seems to make to no difference (in case it made dodgy connection)
- Tried jump starting from my other car. No Change
Current status - turn key and dash light up. All ancillary services activate like they should with a fresh battery. Fuel pump primes.
Press starter button. One click / light clunk and nothing. Occasional buzzing noise, although sounds like its coming from the injector area..
I have a used starter to try change next, but other than that, I'm out of options..
Anything else before the Viking funeral?
Edited by Rosssco, 12 December 2018 - 10:39 AM.
#2 Richard Hoogeveen
Richard Hoogeveen
  • 73 posts
Posted 12 December 2018 - 10:33 AM
Did you try to change out the brown relay ?
Verstuurd vanaf mijn SM-N950F met Tapatalk
#3 Rosssco
Rosssco
  • 4,185 posts
Posted 12 December 2018 - 10:37 AM
Have not Richard. That's the ECU relay, but the engine should still crank either way, but it isn't.
#4 FLD
Posted 12 December 2018 - 10:59 AM
Poor earth? Clicking is a sign of weak current, sounds like it should be in the battery circuit
#5 Rosssco
Rosssco
  • 4,185 posts
Posted 12 December 2018 - 11:13 AM
Where is the question.. I assume the starter just earth off the block (as its connected to it), so the earth between the block / gearbox and the chassis..?
It was starting fine though (while static). Only thing I can think there is that earth cable was removed while I was pi$$ing about with coolant hoses, and not properly reconnected, then came loose during test drive..  :huh:
#6 FLD
Posted 12 December 2018 - 11:15 AM
There's an earth cable to the chassis on mine by the oil cooler.
ETA: It's worth checking before swapping starter and other bigger jobs.
Edited by FLD, 12 December 2018 - 11:15 AM.
#7 Rosssco
Rosssco
  • 4,185 posts
Posted 12 December 2018 - 11:23 AM
Think that was is ok, but tbh, I couldn't properly see down that area due to header tank and CC tank mounted above the gearbox..
#8 Rosssco
Rosssco
  • 4,185 posts
Posted 12 December 2018 - 11:29 AM
This thread seems to be similar-ish issues..
http://www.vx220.org...ounding-points/
#9 Talk-torque
Talk-torque
  • 150 posts
Posted 12 December 2018 - 01:59 PM
Our starting issue, similar to yours, was a duff starter, but that wouldn’t explain the car stuttering and stopping. Have you checked the Loom of Doom?
#10 jonnyboy
jonnyboy
    The hardtop guy
  • 8,290 posts
Posted 12 December 2018 - 02:05 PM
Make sure on the connector terminals on the block for the relays haven't pushed back when the relays have been pushed in and out.
#11 Rosssco
Rosssco
  • 4,185 posts
Posted 12 December 2018 - 02:08 PM
Well my next option was to swap the starter. Its certainly easier looking to swap than an alternator (apart from the upper bolt).
Have checked it quickly. Never had any issues with it. Plus with ign on, I can hear the throttle working upon pedal application, and that's usually the thing that goes..
#12 Rosssco
Rosssco
  • 4,185 posts
Posted 12 December 2018 - 02:09 PM
Pretty sure I checked that, but its worth a double check..  thumbsup
#13 jonnyboy
jonnyboy
    The hardtop guy
  • 8,290 posts
Posted 12 December 2018 - 06:48 PM
I had the coil on a fuel pump relay push out the back a few years back
#14 TheRealVXed
TheRealVXed
    Sidekick
  • 5,975 posts
Posted 14 December 2018 - 01:25 PM
Check the starter solenoid.  The click will be the relay that activates it, but any loss of current in the main solenoid circuit will mean the starter motor won't have enough current to crank the engine.  I would start with the earth cable to the block before replacing the whole thing...
#15 ICD
ICD
  • 102 posts
Posted 14 December 2018 - 01:59 PM
Lack of fuel...it has been known....
..a well known hooner did everything you have done......except check there was fuel in the tank....
#16 Rosssco
Rosssco
  • 4,185 posts
Posted 14 December 2018 - 02:33 PM
Yeah, there's a click like a little metal hammer hitting something, then nuffin.... I'll try check the earth noted. Checked the chassis earth and it was fine..
#17 Rosssco
Rosssco
  • 4,185 posts
Posted 14 December 2018 - 02:34 PM
The thought did occur to me as the level is low, but this wouldn't affect the engine cranking (which it isn't)..
#18 FLD
Posted 15 December 2018 - 01:40 PM
Looks like you're into a starter swap :(
That top bolt isn't too bad, just use a long extension bar and you'll get it. thumbsup
#19 Ivor
Ivor
  • 2,212 posts
  • Interests:Sheep & Ducatis
    and now bees
Posted 16 December 2018 - 08:48 AM
Can you get a jump lead to the starter to see if it turns?
#20 Rosssco
Rosssco
  • 4,185 posts
Posted 17 December 2018 - 09:10 AM
Yep, starter replaced yesterday for an exceptionally dirty one from fleabay.
No change. Doing exactly the same as before. Load buzzing from (what sounds like cylinder head). And same click as before with no sign of starting.
Also checked:
- Earth from g/box to chassis
- Changed out coilpack from brand new (had bought as spare)
- Charged an old battery and swapped - no change
I'm clean out of ideas now. Thing has been abandoned to fill up with Scottish rain water and hopefully die until the new year, when I might summon some motivation to remove the rear clam again and check all wiring, as that's what its down to..
