4.17 Gearbox Wanted
11 replies to this topic
#1 tommobot
tommobot
  • 1,008 posts
Posted 03 January 2019 - 04:32 PM
As title, 4.17 gearbox wanted.
#2 sford
sford
  • 1,459 posts
Posted 04 January 2019 - 10:02 AM
Back on the mods then!
#3 tommobot
tommobot
  • 1,008 posts
Posted 04 January 2019 - 10:12 AM
Not willingly... Took rear subframe off, discovered massive crack in gearbox / bell housing casing...  :mellow:
If I'm getting a replacement, might as well try and 'upgrade'..
#4 Johnboyhgt
Johnboyhgt
  • 1,313 posts
Posted 04 January 2019 - 06:10 PM
Is it at the bottom ?
Between the 2 sump 19mm bolts ?
#5 tommobot
tommobot
  • 1,008 posts
Posted 04 January 2019 - 06:51 PM
Nope, just next to the 19 and 17mm bolts for the rear engine/gearbox mount..
#6 tommobot
tommobot
  • 1,008 posts
Posted 11 January 2019 - 09:27 AM
Alternatively, if someone had a scrap / dead F23 bell housing that they were not using that would also suffice...
#7 Nev
Posted 12 January 2019 - 07:38 AM
I you help me take my F23 out of my VXT you can have it for free. The housing is fine on it.
#8 vocky
Posted 12 January 2019 - 08:29 AM
z22se bellhousing is different to the vxT
#9 Nev
Posted 12 January 2019 - 08:39 AM
Ah, he's NA then I take it. Poop.
Edited by Nev, 12 January 2019 - 08:40 AM.
#10 tommobot
tommobot
  • 1,008 posts
Posted 12 January 2019 - 09:02 AM
Dang. Vocky can you confirm what would be a straight fit in terms of coding onto a NA?
#11 vocky
Posted 12 January 2019 - 09:59 AM
the vx220 uses the astra G z22se gearbox, not sure why they gave it a seperate code - TN
Astra is the SF or AH, both being the 3.95 FD
The zafira A z22se used the SG 4.17 FD gearbox (the AQ is also a 4.17 zafira box)
You could buy a 4.17 FD gearbox from the Signum z22yh = XY, but then you would have to swap the bellhousing with a z22se item due to the deeper position of the slave cylinder on the z22yh - for the dual mass flywheel.
#12 vocky
Posted 12 January 2019 - 10:15 AM
there is one zafira z22se F23 4.17 on ebay, the later spec AQ, but it's way overpriced at £400 :huh:
https://www.ebay.co....mCondition=3000
