36 Tooth Trigger Wheel Position And Delta Ecu
3 replies to this topic
#1 Mat Jackson
Mat Jackson
  • 1,276 posts
Posted 31 March 2019 - 07:10 PM
Working through fitting the new SCS ecu, and will be fitting a 32 tooth trigger wheel to. Is there a standard position for the missing tooth to be at TDC, or will it very ecu to ecu...
#2 quimbles
quimbles
  • 704 posts
Posted 01 April 2019 - 11:19 AM
you can adjust the offset in the software.
I'd just ask SCS to check the wheel matches one in the software.... They gave me the settings then Vocky installed.
I'm using the internal 60-2 90degress btdc
I guess for the external one you can set the sensor at an angle of your choosing?
Sent from my Mi A2 Lite using Tapatalk
#3 Mat Jackson
Mat Jackson
  • 1,276 posts
Posted 01 April 2019 - 06:35 PM
Just spoke to Simon and it’s also 90 deg btdc too...
#4 quimbles
quimbles
  • 704 posts
Posted 02 April 2019 - 08:05 AM
thumbsup
