Engine Management Light After New Spark Plugs, Coil Pack And Cam Shaft
#21
Posted 13 April 2019 - 09:07 PM
#22
Posted 13 April 2019 - 09:38 PM
With the original coilpack and sparks getting corroded in storage, is it safe to say storage was damp?
#23
Posted 14 April 2019 - 05:41 AM
#24
Posted 14 April 2019 - 06:07 AM
With the original corosion problem, the next thing to check are the connectors behind the header tank.
Also referred to as the loom of doom.
#25
Posted 14 April 2019 - 07:01 AM
the easiest method of checking that you have an oem coilpack is there will be a white sticker where the badge goes
pattern coilpack
https://www.ebay.co....L-/323400119714
oem coilpack
https://www.ebay.co....0537/1527452107
#26
Posted 14 April 2019 - 08:02 AM
#27
Posted 14 April 2019 - 08:37 AM
#28
Posted 14 April 2019 - 08:41 AM
hopefully they have another 2.2 vx220 and can swap the coilpack with for a quick test, either way the guys at Back on Track will sort it for you
#29
Posted 08 May 2019 - 09:38 AM
Give Liam a call at MMG Performance he's never failed me, he knows all there is to know with these VX's.
Worth the drive up to Derby
#30
Posted 08 May 2019 - 11:45 AM
Have you checked the battery terminals are clean and tight? I know it feels like I am clutching at straws but I've heard of stranger things...
#31
Posted 20 July 2019 - 12:22 PM
New coil pack etc went in but it did not fix the car... various sensors got changed and even the chain but the problem was actually the ECU. Rather than pay £1.1k + vat from Vauxhall I bought a 2nd Hand Vectra ECU... this did generate a fuel sensor error code but after a very helpful FB owners group feedback this was fixed. Should anyone want to know what the fix was for the Vectra ECU it was “ They should be using an MDI to use Tis2Web to download the new software (which is actually old software) to turn it into a vx220 controller. This turns off a whole bunch of crap that we don't use in our cars. Then set the variant configuration using tech 2“
New coil pack,
Chain,
ECU
Labour split across BOT and a main dealer
£2k... could have been a lot worse! But it did take 3.5months..
#32
Posted 20 July 2019 - 12:28 PM
#33
Posted 20 July 2019 - 12:29 PM
Glad your car is back and sorted buddy enjoy it now, heatwave on its way
#34
Posted 20 July 2019 - 01:06 PM
Come on heat wave!!!
