Switch For Abs Cutoff
34 replies to this topic
#21 -Dab-of-Oppo-
-Dab-of-Oppo-
    Cuntpuffin
  • 3,646 posts
Posted 06 May 2019 - 04:06 PM
A little more subtle than a switch on the dash saying "ABS ON/OFF".
What like this?! :lol:
Mine is specifically declared and listed on my insurance along with everything else.
#22 Sutol
Sutol
    Well it's nearly a Lotus
  • 8,120 posts
Posted 06 May 2019 - 04:44 PM
You are kidding me ffs. Your ins. Co can't know what ABS is lol.
I have never seen the point of a switch. I only disconnect mine for track days. If it was a problem on the road it would be disconnected all the time.
#23 TheRealVXed
TheRealVXed
    Sidekick
  • 5,975 posts
Posted 08 May 2019 - 11:53 AM
I have a key switch on mine, located in the conventiently sized circular hole in the black cowling right above the wire.  Everything is hidden so you can't see what it controls, and can only be switched on and off using a key, which is on my ignition keys and therefore can't be accidentally turned off while ignition is on.
One like this.
https://www.ukdj.co....-two-keys-p5812
#24 alesaux
alesaux
  • 28 posts
Posted 03 July 2019 - 02:41 PM
So decided to do this prior to my track day on Friday but I've come across a slight issue. I have found two identical yellow wires. Not sure which to cut.
any ideas?
#25 Mobile Chicane
Mobile Chicane
  • 118 posts
Posted 03 July 2019 - 03:58 PM
any ideas?
They're not identical. One has a grey stripe, leave that one alone. Only cut the wholly yellow cable. Good luck!
Edit: oh yes, and the fully yellow cable is wrapped around a pink cable, the striped one isn't wrapped around any other cable.
Edited by Mobile Chicane, 03 July 2019 - 04:00 PM.
#26 alesaux
alesaux
  • 28 posts
Posted 03 July 2019 - 04:19 PM
any ideas?
Attached File  IMG_1953.jpg   342.33KB   5 downloads
#27 alesaux
alesaux
  • 28 posts
Posted 03 July 2019 - 04:20 PM
any ideas?
defo two solid yellow wires but one is in a sheath at the end with a pink wire so that’s the one I’ll go for
#28 Mobile Chicane
Mobile Chicane
  • 118 posts
Posted 03 July 2019 - 04:33 PM
Turn the wire around, the grey stripe is very faint but it's there.
#29 Mobile Chicane
Mobile Chicane
  • 118 posts
Posted 03 July 2019 - 05:18 PM
Here's the aforementioned grey stripe, only visible when I twisted around the wire.
Attached File  IMG_20190703_181339_compress4.jpg   149.06KB   4 downloads
#30 alesaux
alesaux
  • 28 posts
Posted 03 July 2019 - 05:21 PM
Cheers All. think this id done now.. will take it out for a run in a while and try some aggressive braking and see what happens
#31 alesaux
alesaux
  • 28 posts
Posted 03 July 2019 - 07:19 PM
Thanks to everyone for their help. Just been out in it and the brakes are so much better with the ABS off. Cadwell Park on Friday should be much better :-)
#32 Steviejay
Steviejay
  • 51 posts
Posted 03 July 2019 - 08:53 PM
Can you not just remove the abs fuse?
#33 alesaux
alesaux
  • 28 posts
Posted 03 July 2019 - 08:57 PM
of you do this you lose the speedo as well as it’s on the same circuits
#34 alesaux
alesaux
  • 28 posts
Posted 03 July 2019 - 08:59 PM
I like the look of this one. Where did you find it ?
#35 -Dab-of-Oppo-
-Dab-of-Oppo-
    Cuntpuffin
  • 3,646 posts
Posted 03 July 2019 - 09:15 PM
I made it, it's just a basic key switch stuck through a bit of aluminium with a sticker I designed and printed.
You can get get the top right one of these switches if you wanted a fancier logo'd up solution.
