Please be gentle with me....
Are there any alternatives to fitting the Brembo calipers on the rear?
Has anyone fitted other calipers?
Thanks.
Posted 13 May 2019 - 03:41 PM
Thanks.
Posted 13 May 2019 - 04:02 PM
Posted 13 May 2019 - 07:29 PM
Thanks.
For what reason?
Posted 14 May 2019 - 06:07 AM
Are the rears not shared with a Dodge Viper or something, and a couple of other random cars..?
Posted 14 May 2019 - 06:56 AM
The reason for my question is that whilst I have refurbed ones on the rear of Vix plus another pair in the shed which require refurb, it would appear they are a right royal PITA if grub screws, etc are beyond help.
So....was thinking there may be an alternative off the shelf solution which is also cheaper.
Thanks.
Posted 14 May 2019 - 08:16 AM
It is believed that the caliper is shared with a Dodge Viper and a Renault 21 turbo, but never really proven afaik.
I think your most affordable option is from a low mileage breaker elise/exige or vx220.
Posted 14 May 2019 - 11:21 AM
Actually, you don't need to touch the grub screw unless there is a leak through it. You can pop out the mechanism (and assemble it back) through the back of the caliper.
Posted 14 May 2019 - 11:27 AM
The inside mechanical parts are the same, but the casting of the caliper width is different.
The Renault ones are much more narrow to fit over a non-vented (10mm thick) brake disc and the opposite is the Viper which AFAIK uses closer to 28-30mm vented discs.
Of course in EU/UK the Viper ones are rare as hen's teeth anyway, so that doesn't help as a source anyway
Rebuild kits for the Renault ones are fine to use on the VX/Elise ones and even new/rebuilt calipers from these sources can be gutted for the parts to fit in the VX/Elise ones and refresh them or get the special parts like the grub screws that are un-obtanium otherwise.
Posted 14 May 2019 - 11:39 AM
Posted 14 May 2019 - 12:20 PM
Looking at how much i pissed away on this car over the years, a new set of rear calipers are not the end fo the world.
But i understand it's not for everyone.
