Door Handle Cable
6 replies to this topic
#1 ChrisO_VX
ChrisO_VX
  • 62 posts
Posted 30 June 2019 - 01:02 PM
Booked in for an MOT on Tuesday and the (drivers side) door handle isnt working.  The end of the cable (at the handle end, not the lock) is broken, so itsnt able to attach itself to the handle.
Any thoughts?  Searched but cant find a part number (or if it's a common part on other Vauxhalls - although someone mentioned it could be off a Rover 25?  I'd imagine they're like hens teeth in the scrap yards now)
#2 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 30 June 2019 - 03:37 PM
32 is part number 9197151
33 is part number 9197918
I'd originally thought you needed the clips but on second viewing of the above image I suspect that the plastic 'end connector' which you need is part of the rod
#3 ChrisO_VX
ChrisO_VX
  • 62 posts
Posted 30 June 2019 - 04:21 PM
Apparently the clip (or part 33) is available from someone in Russia (!!!) but the rod (32) isnt recognised anywhere.
Probably have to make something FFS!
#4 vocky
Posted 30 June 2019 - 05:35 PM
normally just the plastic clip breaks on the handle, where the rod connects, they are a very common part available from most breakers
the metal rod is far less likely to break.
I might have one, will have a look
#5 ChrisO_VX
ChrisO_VX
  • 62 posts
Posted 30 June 2019 - 06:10 PM
Aye the clip has broken.
If you have one, I'd be eternally grateful.
#6 vocky
Posted 30 June 2019 - 08:21 PM
I cannot find the clips, but part 29 is the same
it's only £1.31 new from Lotus (S1 part 11) = https://www.deroure....=0&PBID=1305493
ps: if you click on 'which car does this fit' it lists every Lotus model
#7 ChrisO_VX
ChrisO_VX
  • 62 posts
Posted 30 June 2019 - 09:29 PM
Ordered.
Thank you.
Massive thanks to Packs for coming to the rescue ealier, and with a hangover!
