Pcv
4 replies to this topic
#1 scw02102
scw02102
  • 1,581 posts
Posted 02 July 2019 - 09:11 PM
After chatting to turbo Technics last week they recommended changing the PCV at the same time as fitting my turbo
I haven't read much or any about people changing this.
Is it worth it? They are fairly cheap and these engines are 10 years plus so im guessing the valve will be getting old?
#2 james4563
james4563
  • 268 posts
Posted 04 July 2019 - 06:14 PM
https://m.ebay.co.uk...epid=1733624145
Just a one way valve so you probably can get one even cheaper somewhere. Not sure how often they fail tho. My understanding is that if it fails you'd be leaking boost through into the rocker cover and pressuring the whole system when on boost.
#3 ayresyy
ayresyy
  • 490 posts
Posted 05 July 2019 - 07:04 AM
They do fail a lot! especially if you run higher that standard boost. Easy to check if it's failed by just pulling the throttle body pipe end off and blowing through it back towards the engine.
#4 siztenboots
Posted 05 July 2019 - 08:54 AM
90423045 , is the part number . I will check the dimensions later and find something equivalent. I suspect the saab one will fit
#5 scw02102
scw02102
  • 1,581 posts
Posted 19 July 2019 - 04:59 PM
thanks guys for £20 I will just change it anyway, least I know its been done
