Saab Engine In Vx220 Turbo
25 replies to this topic
#21 Rosssco
Rosssco
  • 4,185 posts
Posted 01 August 2019 - 08:39 PM
you could modify the subframe and use an Opel F40 6 speed gearbox.
I always wondered if anyone had any pics or other info one this subframe mod..
Plus I think the driveshafts are different splined / length, and the gear selector would need modded (similar to an M32 swap)?
#22 vocky
Posted 02 August 2019 - 09:25 AM
people have fitted the F40 to astras, so driveshafts must be interchangeable.
Not really sure what the subframe mod is, but I do recall it involves cutting a chunk away to allow the end of the F40 to clear
#23 siztenboots
Posted 02 August 2019 - 10:48 AM
also the B206 is the nicer block than B204 without balancer shafts
#24 Rosssco
Rosssco
  • 4,185 posts
Posted 02 August 2019 - 11:46 AM
Good point. And the F40 comes in some Vectra's which use the same hub unit, so..
#25 OneYet
OneYet
  • 1,355 posts
Posted 04 August 2019 - 09:14 PM
You should talk to Speedsterspeed.
Look at Rejsa.nu.
He did this registration to a Speedster NA.
He did not change the gearbox but more or less all the suspensionparts instead. And the engine. And the braking system.
#26 Nev
Posted 18 August 2019 - 02:15 PM
FYI Phil Hilyard in his B204 based VX220 just won his class at Race Wars 2019, with a 11.9s 1/4 mile time and a 0-60 @ 3.90s!!
That's with just 280 or 300 odd HP if I remember correctly.
Edited by Nev, 18 August 2019 - 02:16 PM.
