Help Needed - Vxt Compression Test
5 replies to this topic
#1 Pipo
Pipo
  • 876 posts
  • Interests:Computer, automotive technics, electronics, MTB, Alpine ski, playing keyboard.
Posted 23 July 2019 - 10:38 PM
Hi guys,
I need some info, and after one hour search I'm left a bit confused. as I read several contradiction numbers.
At this moment my VXT is for sale.  In 2 weeks a buyer is coming to check my car.  But as he's coming from abroad, he asks me to go to a service centre to let them make an official compression map of the 4 cylinders.
I driving a full stock VXT, (2.0 turbo) with no engine modifications whatsoever and only 27.000 km (about 16.800 miles) on the counter.  I only replaced the precat by a straight pipe (second maincat is in place).  And replaced the silencer by a sports silencer of VX-Performance.
What is the factory compression I should read by performing a compression test?
I also suppose a dynorun would show a bit more then the factory 200 BHP ?
Your help will be much appreciated :mellow:
#2 chris_uk
Posted 24 July 2019 - 01:00 AM
i think its about 175psi..
different gauges can sometimes read high/low.. the important thing is that they are all within X across all 4.
#3 Nev
Posted 27 July 2019 - 05:31 PM
170 PSI is good, 150 PSI is acceptable. That is with oil on the rings and at normal operating temps.
#4 hairy
hairy
    Moonlander
  • 6,064 posts
Posted 27 July 2019 - 10:10 PM
Yes agreed
Some background info for you: https://www.vauxhall...l-engine.71683/
#5 scw02102
scw02102
  • 1,581 posts
Posted 20 August 2019 - 06:50 PM
I had mine checked a few moths ago
I got 175psi to 180psi on all 4 cylinders
Apparently that was good (2.0 turbo) so anywhere near that would be ideal
Test takes a few minutes but I would say around 30 mins start to finish including taking the plugs out etc
Edited by scw02102, 20 August 2019 - 06:51 PM.
#6 Matthew Bentley Racing Ltd
  • 774 posts
Posted 21 August 2019 - 08:32 AM
As Above,
Anything 150PSI over is perfectly acceptable. Its more important that they are within 5-10psi of each other - thats what would put a buyer off.
MBR
