Posted 31 July 2019 - 07:48 AM
I have a new abs module sat on the shelf, I am about to pass onto someone who needs one, however I have recently been thinking that a new module may need to be programming to the car? I don’t want to pass it on unless I know it will work.
I remember the 4 channel ones required this but a replacement 2 channel ?
Thanks
Posted 31 July 2019 - 10:40 AM
Posted 31 July 2019 - 10:54 AM
Posted 01 August 2019 - 09:56 AM
Posted 01 August 2019 - 11:20 AM
Posted 01 August 2019 - 08:17 PM
It'll need the usual reset if its brand new. No biggie. If it's 2 channel it might be possible from OP-COM.
What is actually changed by the reset?
Posted 02 August 2019 - 12:35 PM
It sets the zero point in the ABS. When new the unit knows nowt, it just needs to learn 'normal'. It's a nothing job, just click the reset button.
Posted 02 August 2019 - 02:36 PM
Thanks. I was interested because they blew a bulb when they did mine so still curious as to what went wrong.
Posted 03 August 2019 - 10:20 AM
How does one do the initial reset? I've got access to op-com, is it something within the ABS controller there?
Posted 03 August 2019 - 05:00 PM
It has to be done by Lotus with their special yellow cable
Posted 03 August 2019 - 07:33 PM
Guess I need to find a friendly lotus garage then
Posted 03 August 2019 - 08:31 PM
Some will do it for free, others want paying for their time.
Posted 03 August 2019 - 11:08 PM
Thought only for the Exige 4 channed] ABS set-up you need a Lotus dealer cable.
But for a new standard VX220 (NA or T) ABS module learning you can go to your local vauxhall dealer (Tech 2 )...
Posted 04 August 2019 - 01:51 PM
That's on the 4 channel. The 2 channel can go through opcom
Posted 04 August 2019 - 06:42 PM
Posted 04 August 2019 - 07:15 PM
Apologies, my mistake
Posted 04 August 2019 - 09:14 PM
Posted 05 August 2019 - 11:54 AM
Posted 05 August 2019 - 04:47 PM
I'll be having a look tonight or tomorrow, so will see what I find when I connect up opcom will report back!
Posted 05 August 2019 - 05:25 PM
I've just had a look around in OPCOM with the current ABS module installed to try find how out the reset works.
In the version I'm running when I go into the ABS controller all I get is greyed out boxes, other than fault codes.
Am I missing something? Wondering if wrong version of OPCOM or something or whether there's some other way in?
I guess it could also be the cheap opcom being the issue, but if so then I wonder how I was able to programme the immobiliser to recognise new keys previously... hmmm
Thanks
M.
Edited by maq, 05 August 2019 - 05:27 PM.
