Bush Lubrication
Posted 02 August 2019 - 06:03 PM
I'm pretty sure the creeking when there's movement in the suspension of my vx is coming from the front. Maybe the Arb?
I have this kit https://www.elisepar...ushes-rear-set/ fitted throughout which was done 2013 / 14 I understand it can be lubricated in situ, can anyone confirm this and recommend a good way to do this and what to use?
A syringe maybe?
Thanks in advance
Dan
Sent from my G8441 using Tapatalk
Posted 02 August 2019 - 09:34 PM
usually this comes from the ARB bushes bud, remove them, grease them and refit
Posted 03 August 2019 - 05:07 AM
Any particular grease?
Silicone grease is best for rubber isn't it?
Posted 03 August 2019 - 06:52 AM
Posted 05 August 2019 - 05:33 AM
Graphite might work well too, being non liquid it might last longer in there as it won't squish/leak out on a hot summers day. Best to know exactly what material the bushes are made from, and find out what's best for that material.
Edited by Nev, 05 August 2019 - 05:34 AM.
Posted 05 August 2019 - 09:06 AM
Posted 05 August 2019 - 09:42 AM
Posted 05 August 2019 - 10:00 AM
The only way to permanently silence the bushes supplied with the thicker ARBs, is to chuck them in the bin and replace with a Powerflex style softer alternative.
Alternatively, chuck the thicker ARB in the bin and return to the peace and reliability of standard.
Posted 06 August 2019 - 01:21 AM
Stop being grumpy 1" arb is the way forward
Posted 06 August 2019 - 06:31 AM
I didn't find that TBH, caused far too much understeer, I've had mine detached for a year or so now and intend to put an OEM one back on.
Posted 06 August 2019 - 07:33 AM
Nev for mod
Posted 11 August 2019 - 09:36 AM
I've made a cover to go over it now to keep the shite out when I get caught out in the rain next ... Or most likely next years national
