Help.. Bent Woodruff Key.. Z22Se
#21
Posted 28 September 2019 - 04:10 PM
If you move the crank, asking as the uppermost pistons go down you will be fine...
If moving the cams, you risk damaging a valve if one of the pistons is near the top...
#22
Posted 28 September 2019 - 04:13 PM
How can I rotate both the cams, and crank without risking clash?
#23
Posted 28 September 2019 - 05:06 PM
set the crank woodruff key to the 3 'O' clock position or 9 'O' clock
#24
Posted 28 September 2019 - 06:02 PM
Check with a dowel or similar through spark plug holes that pistons are level across all 4..
On that basis I should be able to rotate the cams 360 if needed?
The cam sprockets can only fit on 1 place I believe..
Fit sprocket and try and line up the timing marks as best as possible..
Rotate engine with chain fitted to check?
It sounds a recipe for disaster 🙄
How do I ensure the coloured markers line through on the chain as surely if the crank is at 3oclovk it won't line up at all?
Or am I missing something?
#25
Posted 29 September 2019 - 07:45 AM
Right, so Woodruff key to 3o'clock..
Once you’ve got the cams in the right position, rotate the crank to get it to no1 tdc - the dowels will help spot this...
Then fit the chains as the coloured links will then line up with the timing marks
#26
Posted 29 September 2019 - 08:21 AM
Crank pulley currently at 3 o'clock, ensure pistons are mid stroke.
Fit sprocket and adjust c to have lobes 1 & 4 at 12 o'clock..
Rotate crank to 1 o'clock.. am I ok to turn anti clockwise from 3 o'clock to get to the 12 o'clock position?
Fit cam chain.
#27
Posted 29 September 2019 - 01:40 PM
Impossible to touch anything that way.
Edited by chris_uk, 29 September 2019 - 01:42 PM.
#28
Posted 29 September 2019 - 01:52 PM
Ok.. I think I understand now..
Fit cam chain.
cylinder 4 needs to have the cam lobes sort of pointing towards each other - 10 'O' clock and 2 'O' clock
crank pin should then be at 12 'O' clock
you will not have any issues with valves touching pistons if you do that
#29
Posted 29 September 2019 - 02:01 PM
#30
Posted 29 September 2019 - 02:02 PM
that is correct, cylinder 4 is next to the gearbox
#32
Posted 29 September 2019 - 04:13 PM
Ok, I've had a read through vockys linked thread.
I've re-fitted the chain loosely, using the ext marker point cable tied to the chain, and lined up the crank and exhaust cam as good as possible.
Then re-fitted the intake sprocket aswell.
Nothing has moved in the engine since chain wwas removed.
Im thinking turn over engine until crank at 12o'clock and then remove / recheck timing on chain?
Thoughts... ?
#33
Posted 29 September 2019 - 04:23 PM
However, it will be pretty close and good enough to turn the engine by hand to a position where you can set the timing with the coloured links...
#34
Posted 29 September 2019 - 04:25 PM
As above, that will work fine. As long as the plugs are out it'll turn relatively easily so just don't force any undue resistance.
#35
Posted 29 September 2019 - 04:50 PM
Should this be 100% rigid?
#36
Posted 29 September 2019 - 06:05 PM
quite normal
#37
Posted 01 October 2019 - 11:20 PM
Seems to be a right old faff activating with a pry bar, worked first time round but not this time!
#38
Posted 02 October 2019 - 07:28 AM
I would always install the cam chain tensioner fully activated
