Vx On Itbs Not Starting
Posted 15 November 2019 - 09:59 PM
Car used to run as stage 1 on alpha with no issues. This year it’s been upgraded to stage 2, with new head and cams and also upgraded to delta SCS ecu with 36-1 trigger wheel. Since then, the car generally won’t start, but will do occasionally... However, if I switch back to alpha ecu and trigger wheel it will.
As it’s intermittent, I thought it was an issue in the loom, particularly the link loom from the original alpha loom to the new SCS ecu.
So, built a new engine loom from scratch for the SCS and installed it last week. Engine started first time, although didn’t sound like it was firing on all the cylinders all the time. Since then, it won’t start....
I’ve tested all the wiring, and found no issues... I’m getting fuel, but think there is a weak spark. In the past (on the SCS ecu) I’ve had issues with it only firing on cylinders 1 and 3, and at other times just on 2 & 4. With the plugs on the rocker cover I can’t get a spark unless they are earthed by wire to the main block.
Also tested the timing and that’s spot on, and ecu is showing it recognises the crank sensor ok and is running at 200 rpm at cranking...
Checked tonight, and I’m getting a good 12v plus to the coil pack too, which makes me think an issue with the coil pack itself giving a poor or no spark.
But - why would it run on alpha? Could a breaking down coil work worse on one ecu than the other? The new SCS ecu has been tested on another car and ran fine... If the switched earth for the coil on 1 ecu was different than the other would that be enough to affect a poorly coil pack...
Answers on a postcard...
Posted 15 November 2019 - 10:02 PM
should have fitted a supercharger
Posted 15 November 2019 - 10:03 PM
When I saw you had quoted me I knew that’s what you would have said!!! May be a plan b for me...
Posted 16 November 2019 - 09:55 AM
Coil pack faulty...
Crank sensor not able to work well enough to on 36-1
ECU struggling to read 36-1
Posted 16 November 2019 - 10:58 AM
Posted 16 November 2019 - 11:06 AM
try putting a better earth direct from engine block to ecu , jump leads will do for a test
Will try that!! Have tested continuity from the ecu to earth and it is good - but will try this too..
Through the ecu I think I can fire individual spark plugs, so will use that to check continuity from coil connector to ground..
Posted 16 November 2019 - 11:07 AM
Posted 16 November 2019 - 12:57 PM
Also ordered new coil pack from autovaux - they have a returns policy if it’s not needed...
On electrical items? Are you sure?
Posted 16 November 2019 - 01:45 PM
Yes - if not opened...
Posted 16 November 2019 - 05:30 PM
On another car i had to set it beyond the required distance otherwise it did not work properly...
Edited by 2-20, 16 November 2019 - 05:35 PM.
Posted 17 November 2019 - 02:04 AM
it will be to do with the crank sensor
you have the info in the ecu for a 36-1 yeah?
Posted 17 November 2019 - 08:45 AM
Ecu is set up for 36-1 trigger wheel, and software is showing it syncing too... But still concerned it might be an issue. I’m the only SCS car on 36-1, another is set up with the alpha wheel so might fit that back on and try their map...
But - not sure why it would be intermittent issue though...
Posted 17 November 2019 - 07:04 PM
Also the itbs are really sensitive on the scs setup way more than the alpha. I've had misfiring few times
Posted 17 November 2019 - 08:46 PM
Only the offset you can change. Is it round he right way? Can't remember if there's more than one 36-1 wheel in the menu.
Yeah - checked the wheel with a timing gun and it showed as being spot on. However, did struggle to get a spark when testing the timing which leads me to the coil pack...
Posted 18 November 2019 - 01:58 PM
it was my car running the 36-1 on the webcon alpha ecu and sensor. it did start, albeit with a lot of cranking. i think that was down to the ecu not being able to process that many teeth in the trigger wheel.
so the sensor should be fine.
Posted 18 November 2019 - 02:21 PM
also id check with scs what the spec of the 36-1 trigger is in the ecu.... if its set to run standard ford setting sit could already be say 90 degrees BTDC without touching the offset.
Posted 18 November 2019 - 07:31 PM
Yep - missing tooth is at 90 deg btdc, and timing gun shows it’s in the right place.... Offset in the software is set at zero too...
New coil pack will be here this week, so will try that... After that I’ll try fitting to old alpha trigger wheel as that has now also been mapped in the SCS software....
Posted 18 November 2019 - 08:02 PM
There's also a trigger sync test in the software, have you checked that?
Posted 18 November 2019 - 08:04 PM
What material is the 36-1 made from? Just a thought.
