Vx On Itbs Not Starting
#21
Posted 18 November 2019 - 08:04 PM
#22
Posted 18 November 2019 - 08:10 PM
Zinc passivated mild steel.
Sorry don't know how to reply tapatalk
#23
Posted 18 November 2019 - 09:29 PM
What material is the 36-1 made from? Just a thought.
Wheel is steel, so should work.
#24
Posted 18 November 2019 - 09:30 PM
Ah great that's good to know
There's also a trigger sync test in the software, have you checked that?
Yeah, found that. Software is showing the trigger wheel syncing. The software has been a great help in helping diagnose and rule things out!!
#25
Posted 19 November 2019 - 05:15 PM
#26
Posted 19 November 2019 - 05:55 PM
If you need me to check any readings on the ECU just let me know
Thanks..
#27
Posted 19 November 2019 - 08:31 PM
#28
Posted 24 November 2019 - 03:52 PM
I can smell fuel, but how can I confirm I have it (plugs are wet which is what I expected)...
If I have fuel and spark, I guess the only thing it can be is timing?
#29
Posted 24 November 2019 - 06:18 PM
#30
Posted 24 November 2019 - 07:08 PM
TPS? Think that's the only other one left
TPS is ok on the software (it’s only 6 months old)
#31
Posted 25 November 2019 - 09:26 AM
you can pull the fuel rail open on one of the clips to see if there's fuel........ its a bit messy mind! just prising it open a little will do. ive had a leak there before when its running.
there ant that many sensors it can be, totally baffled!
i feel your frustration.... my car has a misfire. I left it out in the rain the other week tho, so im hoping its the obvious fix.
#32
Posted 26 November 2019 - 09:20 PM
So, latest thinking is trigger wheel / timing...
#33
Posted 26 November 2019 - 09:58 PM
Edited by quimbles, 26 November 2019 - 09:59 PM.
#34
Posted 27 November 2019 - 09:39 AM
Does the circumference of the trigger make any difference?
Also had a random problem at the start where the software didn't prompt for the ECU type and it didn't install the right firmware.
Anyways it has to be the trigger!
#35
Posted 27 November 2019 - 10:35 AM
You tried putting 90 and 270 in the offset. Although I don't think it'll except 270. Maybe turning the sensor round...unsure
This. It's was my problem when installed ITBs first time. I installed trigger wheel with the wrong offset, signal was totally OK, but no the phase.
No start. Probably you can even configure offset in the ECU software.
#36
Posted 08 December 2019 - 05:08 PM
Looks like the stage 1 map was far enough off to not even start the engine!! Who would have thought there would be that much difference!!
