Avon Zzr Vs Advan A052
30 replies to this topic
#21 CocoPops
CocoPops
  • 17,182 posts
Posted 24 August 2020 - 01:40 PM
They are good.
They are soft though.
I’ve now got 3 sets of rears, to my one set of fronts.
#22 piwo
piwo
  • 181 posts
Posted 24 August 2020 - 02:02 PM
You can buy a052 front and zzr rear.
#23 CocoPops
CocoPops
  • 17,182 posts
Posted 24 August 2020 - 02:12 PM
Nah, would rather have matching tyres all round... aesthetics reasonably mainly but also grip levels.
#24 Pidgeon
Pidgeon
  • 5,254 posts
Posted 24 August 2020 - 02:17 PM
I've no experience of the A052 and having looked at the price, it'll stay that way :unsure:
3 times rear to one front is fairly standard?
#25 piwo
piwo
  • 181 posts
Posted 24 August 2020 - 03:42 PM
you will not have the same grip levels on the same tire front - back because the front is usually 10 degrees cooler than the rear. Proven on many tracks and street. So for the grip to be the same the front - rear must be on front a tire with a softer compound. it cannot be otherwise. moreover, your consumption of 3x a052 in the back vs 1x a052 in the front confirms it.
#26 sam220T
sam220T
  • 159 posts
Posted 24 August 2020 - 05:35 PM
They are good.
Interesting. How many trackdays do you usually get out of a set of rears?
If around 3 then similar to what I got out the ad08r. That said everything I've read seems to suggest it's much softer even though they have the same 200 treadwear.
Sam
#27 piwo
piwo
  • 181 posts
Posted 24 August 2020 - 06:13 PM
Yes. Ad08r you can do 50tys km. On a052 mayby 5tys km.
My 215/40r17 a052 in front after 50km on track
IMG_20200823_082232.thumb.jpg.cfadff9111
IMG_20200823_082147.thumb.jpg.77d868f563
#28 piwo
piwo
  • 181 posts
Posted 21 November 2020 - 06:27 AM
https://m.tirerack.c...ab=ResultCharts
Falken Azenis RT660 vs Hankook Ventus R-S4 vs Michelin Pilot Sport Cup 2 Connect (240) vs Yokohama Advan A052
I) wet braking
1) Yokohama Advan A052 107.9feet
2) Falken Azenis RT660 119,5feet
3) Hankook Ventus R-S4 126,4feet
4) Michelin Pilot Sport Cup 2 Connect 129,1feet
II) dry braking
1) Yokohama Advan A052 73,2feet
2) Falken Azenis RT660 73,6feet
3) Michelin Pilot Sport Cup 2 Connect 74,3feet
4) Hankook Ventus R-S4 75,2feet
III) dry lap time
1) Yokohama Advan A052 29,33s
2) Falken Azenis RT660 29,4s
3) Michelin Pilot Sport Cup 2 Connect 29,6s
4) Hankook Ventus R-S4 29,62s
IV) wet lap time
1) Yokohama Advan A052 33,2s
2) Falken Azenis RT660 33,87s
3) Michelin Pilot Sport Cup 2 Connect 34,9s
4) Hankook Ventus R-S4 35,32s
In 2°C outside my yoko a052 is still soft.
Edited by piwo, 21 November 2020 - 06:29 AM.
#29 piwo
piwo
  • 181 posts
Posted 21 November 2020 - 06:40 AM
#30 piwo
piwo
  • 181 posts
Posted 20 December 2020 - 11:15 AM
New opinion
https://www.lotustal...6020/page-6#_=_
Finally got back to Streets of Willow to test out the A052s. Same wheel, suspension, and powertrain setup as the Trofeo Rs. This is an Elise SC with stock motor, 4.8:1 to final drive, non-adjustable Penskes and 15x8 F and 15x8.5 R wheels. Tire sizes for both were 205/50-15 F and 225/50-15 R. The car is about 15 pounds lighter with the A052s due to the addition of a CF bonnet and front access panel. Times are as follows:
Trofeo R best: 1:24.90
A052 best: 1:23.36*
The Trofeo R run was in the morning with air temperatures in the high 40s and calm winds. The A052 run was in the morning with air temperatures in the high 30s and calm winds. For the A052 run, there's a new bump on entry into the back straight chicane that was unsettling the car at the fastest part of the circuit. In later running with the A052s in high 40s temperature, the car was running low 1:24s, but I wasn't pushing quite as hard as in the first session. The Trofeo R was fresh while the A052 already had 3 trackdays and 12 heat cycles on it. Car was driven to the track.
Plenty of people on the internet have already said it, but the A052s are mega fast. They're easily a second faster than the Trofeo Rs in comparable conditions, and probably more than that.
*I was on pace for a lap that might have been in the 1:22s, according to sector times, but a car rejoined the track in front of me and I had to back out of it.
#31 piwo
piwo
  • 181 posts
Posted 17 April 2021 - 01:17 PM
Ps4s 72,78s
Cup2 71,14s
F1 supercar 3 71,77s
F1 supercar 3r 70,44s
R888r 72,25s
does anyone still praises the toyo d888r?
