Im looking to change the oil on my charger, is it possible in situ?
Whats the grade of oil?
How much is required?
I could take it off if required but it would make my life easier if it could be done in situ.
Posted 19 January 2020 - 10:35 PM
Posted 19 January 2020 - 11:56 PM
Posted 20 January 2020 - 10:48 AM
As an aside, how often should we be changing the oil in the supercharger?
Posted 20 January 2020 - 11:22 AM
Depends how often you track it.
Posted 20 January 2020 - 11:23 AM
Eaton says, all 80.000 - 100.000 km (50.000 - 62.500 m), but it's pending on stress (revs, transmission). Max. revs ~14.000.
http://www.eaton.com...t/ct_128484.gif
Posted 20 January 2020 - 04:34 PM
If we say an average of 10 track days per year and around 8000 miles a year in total. What would you recommend @Foxy?
Posted 20 January 2020 - 05:06 PM
You can get most of the oil out using a suitably sized syringe with a tube on it, so you could probably use a vacuum oil changer with suitable attachment instead without taking the charger off.
Posted 20 January 2020 - 05:42 PM
Change it! My guess it's probably never been changed (most haven't). Do it every other year or so?
Posted 20 January 2020 - 06:38 PM
Posted 20 January 2020 - 08:28 PM
to fill to correct level the charger needs to be on a flat level surface and you fill the charger until the oil comes out basically..
Posted 21 January 2020 - 08:48 AM
Posted 21 January 2020 - 09:33 AM
Mine had no oil at all in it! No signs of damage though.
