Hardop Advice Please
27 replies to this topic
#1 martinf
martinf
  • 153 posts
Posted 06 February 2020 - 03:40 PM
Hi all,
I've recently bought an 2.2 NA and have been considering the merits of getting a hardtop.
Could someone please tell me how easy/quick it is to install & remove an (OEM) hardtop. I understand that there is a 'fitting kit' needed - what's in the kit and where could this be bought (assuming the hardtop is supplied without the kit)?
Thanks in advance for any help.
#2 ayresyy
ayresyy
  • 490 posts
Posted 06 February 2020 - 03:55 PM
If you end up with an OEM hardtop you should get everything needed with it. Takes about 10-15 mins to fit/remove it.
#3 hairy
hairy
    Moonlander
  • 6,063 posts
Posted 06 February 2020 - 04:05 PM
Have a look at pages 36-38 of the owners manual.
Edited by hairy, 06 February 2020 - 04:06 PM.
#4 paul_mck
paul_mck
  • 284 posts
Posted 06 February 2020 - 04:19 PM
does a hardtop give more or less headroom than the softtop?
#5 martinf
martinf
  • 153 posts
Posted 06 February 2020 - 04:26 PM
Thanks Guys,
Never thought to look in the manual :huh:
#6 techieboy
Posted 06 February 2020 - 04:51 PM
A bit less and obviously no flex when it comes to crash helmets, cue head canted over at an angle if you're anything over 5'10". It also makes the interior more boomy and is a pain in the arse as there's no way to remove it and carry it with you, if you decide to remove it when you're out and about.
Hard top has been on my car for 4 or 5 days in 14 years, one of which was the day I bought the car back from the dealer and two of which where when the windscreen got replaced.
#7 dstarz7
dstarz7
  • 216 posts
  • Interests:Plastic cars
Posted 06 February 2020 - 06:25 PM
My VX had a hard top fitted when I picked it up. Got home and removed the hard top, hasn't been refitted to the car in nearly 4 years.
#8 myles
myles
    Sausagefest
  • 2,093 posts
Posted 06 February 2020 - 06:53 PM
Get it sold....to me!
#9 apple2000
apple2000
  • 73 posts
Posted 06 February 2020 - 07:27 PM
Have mine on until May then goes back on again in September, its a lotus hard tops with the scoop, personally i cant fault the quality and the fit, miles better in the winter months.
#10 Bakazan
Bakazan
  • 234 posts
Posted 06 February 2020 - 07:57 PM
If you use an electric screwdriver and don't fit the covers you can fit or remove the OEM hardtop in about 90 seconds. I guess it must take a lot longer if you use a hand tool?
#11 martinf
martinf
  • 153 posts
Posted 07 February 2020 - 06:52 AM
Ok, thanks again for all your comments and advice. very helpful.
I'm looking for an OEM hardtop in Silver (the V5 Says "Silver/Blue") - any offers please ! (I'll stick a post in the 'Car Parts for Sale' Section too)
#12 jonnyboy
jonnyboy
    The hardtop guy
  • 8,290 posts
Posted 07 February 2020 - 08:03 AM
I have a sapphire black OEM hardtop available £650
#13 martinf
martinf
  • 153 posts
Posted 07 February 2020 - 08:44 AM
Thanks, but Ideally I'm looking for one in silver.
#14 martinf
martinf
  • 153 posts
Posted 09 February 2020 - 09:01 AM
Hi, Is there any difference between a hardtop for a Turbo or NA, or are they the same?
#15 Strugs
Strugs
    World's #1 cheese fan
  • 3,008 posts
Posted 09 February 2020 - 09:53 AM
Same. Or, if they're not, they're certainly interchangeable.. 👍
Edited by Strugs, 09 February 2020 - 09:55 AM.
#16 martinf
martinf
  • 153 posts
Posted 09 February 2020 - 10:04 AM
Thanks, that's the right answer!
Sent from my LG-H990 using Tapatalk
#17 jonnyboy
jonnyboy
    The hardtop guy
  • 8,290 posts
Posted 09 February 2020 - 10:42 AM
Turbo ones are lined inside NA ones are bare plastic they fit though
#18 smiley
Posted 09 February 2020 - 11:10 AM
Oem, the NA was the same silver color as the window band.
The oem turbo one was painted in car color.
20 years later, many have been repainted to fit peoples taste though.
#19 martinf
martinf
  • 153 posts
Posted 09 February 2020 - 02:14 PM
Thanks for the explanation(s).
I'm a whole lot wiser than I was originally, that's not saying much though 😀
#20 2-20
2-20
  • 1,317 posts
Posted 09 February 2020 - 06:54 PM
Mine is a turbo ..and the lining has started to sag....
If you want to change it you have tp remove the side seals...
