Steering Uj
11 replies to this topic
#1 aquilaproejct
aquilaproejct
  • 267 posts
Posted 26 March 2020 - 09:45 AM
Hey guys, I have slop in my upper UJ.
Will this part suit?
https://www.elisepar...niversal-joint/
Cheers
Anth
#2 paul_mck
paul_mck
  • 284 posts
Posted 26 March 2020 - 09:53 AM
from memory the upper side is not able to be split
#3 aquilaproejct
aquilaproejct
  • 267 posts
Posted 26 March 2020 - 10:17 AM
I can definitely see a bolt on the top side of the upper uj
#4 paul_mck
paul_mck
  • 284 posts
Posted 26 March 2020 - 10:23 AM
ah you know what it is, I bought the EP full shaft with both UJs and the top is welded, oem was 2 x UJs.
#5 paul_mck
paul_mck
  • 284 posts
Posted 26 March 2020 - 10:24 AM
this one: https://www.elisepar...bly-d111h0003f/
#6 FLD
Posted 26 March 2020 - 10:41 AM
There are variants on these.  Early ones were bolt-on at both ends, later ones are welded at one end.  I've not seen one welded at both ends....yet!
#7 aquilaproejct
aquilaproejct
  • 267 posts
Posted 26 March 2020 - 10:55 AM
Mine appear to be bolted at both ends... So presume the Elise part one fits
#8 paul_mck
paul_mck
  • 284 posts
Posted 26 March 2020 - 11:39 AM
iirc on mine the splines on the shaft had worn, not the UJ
#9 chris_uk
Posted 26 March 2020 - 12:22 PM
have you tried tightening the bolt up as tight as you can? loads of times ive fixed play in the UJ by just giving it a tug and its stopped it even tho it didn't even seem to move the bolt/nut.
#10 FLD
Posted 26 March 2020 - 12:51 PM
Must resist innuendo...….
#11 aquilaproejct
aquilaproejct
  • 267 posts
Posted 26 March 2020 - 08:02 PM
Yeah the slop is coming from the UJ itself. It's not rocking on the spline unfortunately. 🥺
#12 aquilaproejct
aquilaproejct
  • 267 posts
Posted 04 April 2020 - 03:58 AM
The answer is no... Not the same. Upper joint is square keyed into top of column and splined for all other joints.... Now trying to find a new upper UJ where it won't cost me 60 pounds to ship to Australia! 😠
