Power Issue - Turbo
13 replies to this topic
#1 denno
denno
  • 1,528 posts
Posted 04 June 2020 - 07:58 AM
Since my intercooler popped a hose a few weeks ago the car has been down on power.
It is most noticeable at around 3.5k rpm In 3rd gear, the engine physically pulls back as if it has hit a wall and the whoosh noise sounds different/ flutters and is louder.
This has started recently after being SORN since November. The only thing I would mention is that after the RAC had got me back on the move following the intercooler hose incident I noticed the screen wash bottle was not secured properly and was nearly empty. Looks like it had leaked down on the battery, not sure if anything else in the front compartment could cause the issue if got wet?
The car is in for service/ MOT next week so I’m after advise on what easy steps to check first while the undertray is off before I start spending on coils packs, Mafs etc.
The car is a stage 4 if that makes any difference. Thanks in advance.
#2 gertje
gertje
  • 459 posts
Posted 04 June 2020 - 08:37 AM
I think they turbo has Broken
Verstuurd vanaf mijn ONEPLUS A6003 met Tapatalk
#3 coldel
coldel
  • 1,183 posts
Posted 04 June 2020 - 09:37 AM
Was the car driven any distance with low coolant after the hose popped?
#4 denno
denno
  • 1,528 posts
Posted 04 June 2020 - 10:04 AM
No, coolant level was fine.
#5 ayresyy
ayresyy
  • 490 posts
Posted 04 June 2020 - 10:16 AM
If you drove any distance at all with a massive boost leak i.e. intercooler pipe off, the turbo could been killed from over speeding. Worth checking the basics first though like any boost or vacuum hose leaks or damaged recirc valve diaphragm.
#6 denno
denno
  • 1,528 posts
Posted 04 June 2020 - 10:30 AM
As far as I’m aware once an intercooler pipe pops off it pretty much kills the power instantly, that’s what seemed to happen anyway and the engine wouldn’t start until the pipe was reconnected. I have heard a few owners have had the recirc valve issue so will definitely ask for that to be checked, cheers.
#7 scw02102
scw02102
  • 1,581 posts
Posted 04 June 2020 - 04:52 PM
Exactly when this happens the car won’t drive and stalls so no way you broke the turbo.
Faulty turbo doesn’t loose power at a set rev range then power comes back in, it just smokes and let’s oil past or just explodes and you will know about it.
Might need a dyno session where the fuel air and boost leaks can be found.
Also worth checking the actuator incase that’s stopping the boost and the power falls off.
#8 denno
denno
  • 1,528 posts
Posted 05 June 2020 - 06:54 PM
Thanks for the replies guys. Dyno session might be a good shout if can’t find anything obvious.
#9 jonnyboy
jonnyboy
    The hardtop guy
  • 8,290 posts
Posted 06 June 2020 - 07:29 AM
Check your fuses. Blown aux water pump fuse will cause this problem.
#10 Ormes
Ormes
  • 4,612 posts
Posted 06 June 2020 - 08:44 AM
As said check all vac lines and operation of the recirc and control solenoids first
#11 denno
denno
  • 1,528 posts
Posted 06 June 2020 - 01:53 PM
Which fuse would that be? Can’t see a specific one for that in the manual?
#12 siztenboots
Posted 06 June 2020 - 04:56 PM
in the boot , same area as the yellow relay
#13 denno
denno
  • 1,528 posts
Posted 07 June 2020 - 02:40 PM
Thanks for the responses guys.
Presuming the water aux fuse was ok and there was no defective boost/ vac pipes found, boost leak/ smoke test was done, would this be the ideal order to start replacIng items?
Change both solenoids
Recirc valve
Wastegate actuator
Map sensor
Coil pack
Plugs
Maf
Anything I have missed or dyno session before changing any of above?
Edited by denno, 07 June 2020 - 02:46 PM.
#14 denno
denno
  • 1,528 posts
Posted 15 June 2020 - 07:49 PM
Just to update on this, had the car in for service and mot today and was a simple boost hose fix thankfully.
