Management Lights
13 replies to this topic
#1 PaulH
PaulH
  • 7 posts
Posted 21 June 2020 - 08:23 AM
I bought a VX220 a few days ago, I'm really enjoying it. The Control Indicator Light has activated and it won't extinguish. I phoned the dealer and he said it is probably to do with the sports exhaust and is nothing to be concerned about.  Whilst this may be ok my mild OCD is kicking in. Any thoughts Guys
#2 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 21 June 2020 - 08:44 AM
It may well just be the sports exhaust and nothing to worry about but as the light being on is now an MOT failure they are just fobbing you off.
Needs the code reading really.
#3 smiley
Posted 21 June 2020 - 08:52 AM
Welcome.
A luggage rack. Now that's is a rare item.
Based on the actual error code, we can give you a good estimate on the actual culprit.
A simple reader is the U480. 2 button operation :tt: Read and clear the code easily.
http://cgi.ebay.co.u...em=113387567465
The odb connector dangles near the middle under your dashboard.
If you want it to clear right now, you can pull fuse 8 for a few sec.
When you put it back, it will arm the alarm, so keep the fob nearby.
When you pull fuse 8 it will also clear the fuel short trim tables, so at first start will sound a bit wobbly for 30 sec. Nothing to be alarmed about.
You can also have it cleared by the people where you bought it, but definitely ask for the actual code before they wipe it.
If there is something off, the code (and thus EML) will come back very soon.
If it is a one-off issue/glitch, it will stay away.
Edited by smiley, 21 June 2020 - 08:59 AM.
#4 oggster
oggster
  • 886 posts
  • Interests:Staying alive 😉
Posted 21 June 2020 - 03:43 PM
Yep rare indeed where did you get it?
#5 hairy
hairy
    Moonlander
  • 6,064 posts
Posted 21 June 2020 - 07:38 PM
Apparently someone is making them:
http://revo-rack.com...0-luggage-rack/
#6 smiley
Posted 21 June 2020 - 08:16 PM
Luckely with suction cups, instead of the oem that required drilling the clam.
#7 Dean_H
Dean_H
  • 10 posts
Posted 21 June 2020 - 10:40 PM
I am in Wigan if you want me to plug Op-Com in and tell you what the fault is?
#8 PaulH
PaulH
  • 7 posts
Posted 23 June 2020 - 04:07 PM
Cheers Zoobeef
#9 PaulH
PaulH
  • 7 posts
Posted 23 June 2020 - 04:08 PM
Welcome.
#10 PaulH
PaulH
  • 7 posts
Thanks Smiley
#11 PaulH
PaulH
  • 7 posts
Posted 23 June 2020 - 04:13 PM
#12 PaulH
PaulH
  • 7 posts
Cheers Dean, I might take you up on that
#13 oggster
oggster
  • 886 posts
Posted 25 June 2020 - 07:22 PM
Cheers..looks decent 👍
#14 oblomov
oblomov
    oblomov
  • 3,885 posts
  • Interests:Mumblers
Posted 27 June 2020 - 07:34 PM
I have one - unfitted - somewhere in the back of my loft.  Not sure if it's worth anything now.
