Vx Specialist South East? Running Problems.
23 replies to this topic
#1 Johnnyjap
Johnnyjap
  • 16 posts
Posted 22 June 2020 - 03:48 PM
Hi all,
Does anyone have any recommendations who to send my poorly 2.2 sc too? I bought Sebs old SC from Jon Seal end of last year.  It keeps occasionally losing power and hunting erratically and only resets when I turn the key off and on again when driving! Took for a spin today and was good for 10 minutes then started doing again.  Ive checked the sparkplugs and all looks dry.
Thanks John
#2 Strugs
Strugs
    World's #1 cheese fan
  • 3,008 posts
Posted 22 June 2020 - 07:36 PM
Back On Track in Guildford.
#3 BrianJ
BrianJ
  • 181 posts
Posted 22 June 2020 - 07:39 PM
Or Plans who are a tad closer to Horsham but I've had really good service from both BoT and Plans so would happily recommend either.
BrianJ
#4 Madmitch
Madmitch
  • 539 posts
Posted 22 June 2020 - 08:24 PM
Sounds like the air mass sensor.
#5 ICD
ICD
  • 102 posts
Posted 23 June 2020 - 07:52 AM
Matt Bentley Racing...nr Bedford, specialist in fault finding
#6 fiveoclock
fiveoclock
  • 9,453 posts
Posted 23 June 2020 - 10:22 AM
Didn't know they'd moved Bedford
#7 Johnnyjap
Johnnyjap
  • 16 posts
Posted 23 June 2020 - 06:28 PM
BrianJ
Thanks for the replies - Bedfords a tad too far Im near Crawley
#8 scw02102
scw02102
  • 1,581 posts
Posted 24 June 2020 - 03:41 PM
I'm Kent and use Back on Track for the past 7 years plus
Worth the drive isn't much Jez doesn't know
#9 siztenboots
Posted 26 June 2020 - 02:12 PM
does it still have the exhaust gas valve EGR fitted or has it been blanked off?
#10 Johnnyjap
Johnnyjap
  • 16 posts
Posted 29 June 2020 - 05:58 PM
EGR blanked off. Been told maybe an actuator issue - drives fine/boosts for a minute or 2 then loss of power and have to rest by key!
#11 The Batman
Posted 29 June 2020 - 06:00 PM
map sensor
#12 Johnnyjap
Johnnyjap
  • 16 posts
Thanks mate - maybe an option Ive got a local garage going to read the codes. My friend thinks its actuator another maf really confused whats going on.
#13 The Batman
Posted 29 June 2020 - 06:14 PM
im in alyesbury, buckinghamshire
it sounds like map sensor to me
#14 FLD
Posted 01 July 2020 - 03:20 PM
Map or some weird LOD.
#15 Johnnyjap
Johnnyjap
  • 16 posts
Posted 01 July 2020 - 08:04 PM
Cheers guys. Well looks like its the map sensor got damp. Hopefully helps if someone else has the same issues as me.
#16 Cavturbo
Cavturbo
  • 388 posts
Posted 01 July 2020 - 08:15 PM
Replace or dry it out?
#17 FLD
Posted 02 July 2020 - 08:07 AM
It's worth checking your laminova seals.  I had an issue with blowing maps and it turned out I was getting coolant on the sensor from the laminovas.  It was a very mild leak so infrequent top ups but inside the manifold was wet with about 1cm of water in the very bottom.
#18 DJ_SL
DJ_SL
  • 425 posts
Posted 06 July 2020 - 01:17 PM
Probably a little late but fwiw recommend Plans. They've been handling mine for the last 10+ yrs. Great service.
Sent from my Pixel 2 using Tapatalk
#19 leevx2.2
leevx2.2
  • 4,830 posts
    getting p!!sed
Posted 06 July 2020 - 06:45 PM
Yes map sensor
#20 The Batman
Posted 09 July 2020 - 12:11 AM
i have brand new seals and end plate gaskets in stock :)
